CFM Frodo Posted July 11, 2022 CFM Report Posted July 11, 2022 use the small sanding compression bit and a wood bead enlarge the hole in the bead, insert the bit and tighten using the compression screw turn the tool on and cut a groove in the bead with a file Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
CFM chuck123wapati Posted July 11, 2022 CFM Report Posted July 11, 2022 i like that !! a lot of uses for a small burnisher!! Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Doc Reaper Posted July 11, 2022 Report Posted July 11, 2022 Frodo, I see I’m not alone, I use a die grinder. I have also ordered a burnishing tool from the “Leather Tool Maker” so I can use the drill press. Quote Doc Reaper
CFM Frodo Posted July 11, 2022 Author CFM Report Posted July 11, 2022 1 minute ago, Doc Reaper said: Frodo, I see I’m not alone, I use a die grinder. I have also ordered a burnishing tool from the “Leather Tool Maker” so I can use the drill press. No, You are not alone. anything beats rubbing and rubbing here is what you do for a drill and drill press need a little epoxy and a drill bit Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
Doc Reaper Posted July 11, 2022 Report Posted July 11, 2022 It’s real close to that, the one sent to me has a 3/16 brass rod for threading holes, I have a harbor freight table buffer but it spins way too fast Quote Doc Reaper
Members dikman Posted July 11, 2022 Members Report Posted July 11, 2022 Neat idea, Frodo. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Thescandall Posted July 12, 2022 Members Report Posted July 12, 2022 I bought these for my dremel tool on Amazon. They work ok. Quote
