Members GavinO Posted July 25, 2022 Members Report Posted July 25, 2022 Hi, As I use old sofa leathers to make my bags, they are often chrome tanned. I am trying to find the best way to finish the edges. These leathers are mosty too supple for bevelling (will rip/not grip smoothly or properly). So I have just been cutting as clean as I can, sanding, adding gum trag, then edge painting. Burnishing in the veg tan sense doesn't seem to be so much a thing. I have watched a few youtube videos and although the description says it's about chrome tanned leather what the youtuber is using looks like veg tan and there are people calling it out in the comments. Very odd. I have been thinking about getting a handheld auto sander/burnisher, like this: https://www.etsy.com/ca/listing/775700174/leather-edge-slicker-tool-sanding-and?gpla=1&gao=1&utm_source=google&utm_medium=cpc&utm_campaign=shopping_ca_en_ca_a-craft_supplies_and_tools-other&utm_custom1=_k_Cj0KCQjw_viWBhD8ARIsAH1mCd4xXWJzyg0-uaJAwLGUgZW_diCMgIlh9k5d6BAICF4K3GjC7vmtMmgaAu_LEALw_wcB_k_&utm_content=go_318291525_19444350045_75295133925_aud-967786719280%3Apla-106551294035_c__775700174enca_554439858&utm_custom2=318291525&gclid=Cj0KCQjw_viWBhD8ARIsAH1mCd4xXWJzyg0-uaJAwLGUgZW_diCMgIlh9k5d6BAICF4K3GjC7vmtMmgaAu_LEALw_wcB&variation0=2426933152 or a modified dremel. Maybe I could use the burnishing attachments to help with the gum trag adherement. If anybody has any experience in finishing somewhat lighter chrome tanned leathers, I am all ears! Gavin. Quote
toxo Posted July 25, 2022 Report Posted July 25, 2022 42 minutes ago, Hardrada said: Folded edge and stitch. This ^ Quote
Members GavinO Posted July 25, 2022 Author Members Report Posted July 25, 2022 (edited) 1 hour ago, Hardrada said: Folded edge and stitch. You mean to just turn in the exposed edges? To be honest I do that most of the time/where possible, but sometimes the build up of layers can become too much and it's better to just have it stitched down flat with an exposed edge. It's for those instances that I want to find an elegant solution. Edited July 25, 2022 by GavinO Quote
CFM Hardrada Posted July 25, 2022 CFM Report Posted July 25, 2022 1 hour ago, GavinO said: You mean to just turn in the exposed edges? To be honest I do that most of the time/where possible, but sometimes the build up of layers can become too much and it's better to just have it stitched down flat with an exposed edge. It's for those instances that I want to find an elegant solution. For thick layers a solution is to cut a strip of leather 1/2" wider than the total thickness and stitch it in as edge cover. Quote
Members GavinO Posted July 26, 2022 Author Members Report Posted July 26, 2022 15 hours ago, Hardrada said: For thick layers a solution is to cut a strip of leather 1/2" wider than the total thickness and stitch it in as edge cover. Yeah I will probably try that out, thanks. Quote
CFM chuck123wapati Posted July 26, 2022 CFM Report Posted July 26, 2022 16 hours ago, GavinO said: You mean to just turn in the exposed edges? To be honest I do that most of the time/where possible, but sometimes the build up of layers can become too much and it's better to just have it stitched down flat with an exposed edge. It's for those instances that I want to find an elegant solution. skive your edges thinner. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
PastorBob Posted July 26, 2022 Report Posted July 26, 2022 tokonole works better on chrome tan than gum Trag. I think the fold over method or overlap method will suffice, but if you find you need to burnish an edge, try the tokonole. Quote In God's Grace, Pastor Bob "While we were yet sinners, Christ died for us." - Romans 5:8 www.PastorBobLeather.com YouTube Channel
Members GavinO Posted July 26, 2022 Author Members Report Posted July 26, 2022 (edited) 4 hours ago, chuck123wapati said: skive your edges thinner. I often find the same issue as with bevelling- the leather is a bit too thin/supple individually and I either rip it or make a messy job of it. Maybe I do need a bit more practice at it though 3 hours ago, PastorBob said: tokonole works better on chrome tan than gum Trag. I think the fold over method or overlap method will suffice, but if you find you need to burnish an edge, try the tokonole. Yeah that came up in my research. I will definitely try this as I haven't been convinced that the gum trag is really doing much Edited July 26, 2022 by GavinO Quote
Members battlemunky Posted July 26, 2022 Members Report Posted July 26, 2022 Tokonole works better but I haven't encountered anything that works as well as painting or rolling the edge and stitching. Its better than gum trag but not an elegant solution, especially if you can't get a good bevel on your edge due to it being too floppy/supple. Quote
