Does any one know how close in size a S&W SD9 is to a Sig 320?
I cannot answer your question, but why are you asking? If you can expand on your question, we may be able to help you better...
I am making a holster for the Smith, and have a dummy for the 320. I was hoping to use it for my mold.
Thanks pastor Bob. I really do appreciate that.
If the holster is an IWB . . . I'd probably use it . . .
OWB . . . it won't work.
IWB relies a lot on the friction created by the human body and the belt . . . so even if it is a bit loose thru the molding . . . body pressure might make the difference.  Plus you could always just run your stitch line a tad closer.
May God bless,
Dwight
www.dwightsgunleather.com
