Machine: Ferdco Superbull 2500 (Juki 441 Clone, like the Cowboy 4500 and Cobra Class 4)
I bought the machine about 2-3 months ago new from Hoffman Bros., it hasn't really had any issues other than a slipping bobbin winder.
I had a binding issue a couple weeks ago and after some research I thought it was an eccentrically drilled presser foot pressure screw
(I think if this is the case, it caused this issue but I am not sure)
Soon after the bind stopped (I don't remember if or how I fixed it)
A couple days ago I noticed my walking foot was traveling WAY higher than the presser foot and I was having issue traveling up layers of material.
So I watched Uwe's video
and this video:
After watching these, I attempted to fix the issue, but it revealed that the problem was much worse.
The walking foot wants to continue to move down after the needle is already on its way back up.
However the presser foot still starts to move up as it should, until it binds.
I believe this is causing the whole machine to bind up as the presser foot continues to push down after hitting the feed dog
The needle to hook relationship is still correct
The walking foot moves backward with the feed dog as it should
The needle still travels backwards with the feed dog as well
I cannot figure out how to make it so the lowest point of the walking foots travel is when the needle reaches the needle plate.
Photos:
The machine when the needle is at its lowest position
The machine when the needle is at its lowest position (presser foot lever raised)
The machine when the walking foot is at its lowest position (presser foot lever is raised otherwise it would bind if I tried getting the walking foot to it's lowest position)
I believe the culprit is one of these two, but I don't want to move anything else around until I know for sure what the cause is.
You need to turn the cam on the topshaft that drive the rods you have circled in red & blue,loosen the 2-set screws & turn alittle @ a time if it gets worse you need to turn the cam the other way.
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
I have done this and got the lowest point on the walking foot to match up with when the needle reaches the needle plate level, however now I am getting a slightly bind whenever the needle is almost to its highest and lowest positions. (the whole machine creaks while I push it through, but doesn't stop stop completely. The needle bar and take up lever seem to vibrate the most as I push it through.)
Additionally I cannot get the presser foot to lift when the walking foot is down.
Edited by Deek
So after fussing with it some more today I have a few notes:
- I believe the other day I actually ended up adjusting the cam all the way around to where it originally was,
so it was probably in the correct position and that the walking foot is still supposed to continue to move down and this causes the presser foot to rise.
- I took the presser bar out of the machine and rolled it on a granite slab to check if it was bent and then pushed it through the presser screw back and forth and met no resistance. I believe that neither of these parts are defective.
- It seems instead of lifting the presser foot after the walking foot goes down, instead all this linkage circled below seizes up.
I gave it a generous oiling after taking putting the presser bar back in, which helped notably, but I do not think this is a lubrication issue.
And when I lift the presser bar on the foot pedal, it unjams.
So is it sewing correctly now?
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Still no sadly,
I took out the linkage entirely, checked for defects found none. (I've basically disassembled/reassembled the entire presser bar / walking foot assembly at this point, I'll check again, but I don't have very advanced measuring instruments, just a granite slab and digital calipers)
I got the presser foot to start lifting as the walking foot goes down again, but then it still jams once its maybe 1-2mm up , if I lightly tap the linkage with a rubber mallet it will begin the move again in spurts.
If I adjust it so the presser foot does not lift at all, then it does not jam, but then obviously it doesn't feed correctly.
The L shaped piece is very slightly bent or maybe unevenly flattened. I put it flat on a granite slab and pressed lightly on it and it wobbles the littlest big.
Visually I can barely even see the unevenness, so I don't think its the cause. But I've been wrong before.
It could be binding on the bracket behind the roller.loosen both screws alittle & lift the foot up & see if it helps,the roller just need to be barely touching it.
Edited by CowboyBob
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
2 hours ago, CowboyBob said:
It could be binding on the bracket behind the roller.loosen both screws a little & lift the foot up & see if it helps,the roller just need to be barely touching it.
That might actually be the problem. I tried adjusting the roller to back plate for tighter clearance on my 4500 and learned that too little caused the foot to bind when lifted. I found a happy clearance and never touched it again. That was years ago.
If the presser bar is out of round in the top third it can bind after lifting.
Posted IMHO, by Wiz
Another cause can be tightening the ring on the pressure foot adjuster,it's best tio leave it loose it can't back itself out.I think once in a while the paint is high in one spot when you tighten the ring & will cause it to bind.
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
All great advice, and I’m probably way off base with the next comment, but I thought I’d throw it out there. .  When I look at the picture  @Deek posted it reminds me of the linkage in a lever action rifle.  Keeping with that thought if you have to take the linkage out again I’d look at the hinge points and where’s movement, see if there is a rough spot or burr that might be catching.  It might be hard to see by eye, so get something soft like a dryer sheet or a Q-tip and run it across the surface, if there’s anything rough it’ll show up.
