Members thekid77 Posted August 7, 2022 Members Report Posted August 7, 2022 Hello leatherworker fam, I make wallets and like to create my patterns on 8 line per inch grid paper (makes it easy to lay out stitching/make the stitching holes land where I want them to)... My issue is that this has never been a problem, as the chisel (Tandy Diamond) points match the lines on 8 line per inch grid paper exactly (see 8 spi photo)... I purchased a 9 spi chisel (different brand) a while back, and the tips of the points do not match the lines on a 9 line per inch grid at all (see 9 spi photo)... I am at a bit of a loss for what to do....if I can't work on a grid I can't reliably lay out the holes for stitching, straddling t slots, etc.... The Tandy chisel lines up to the grid perfectly, but the tool makes huge holes, and the angle of the holes is extremely flat.... For those of you that use stitching chisels, are the teeth evenly spaced between each other? I am at a total loss for what to do... Quote
Contributing Member fredk Posted August 7, 2022 Contributing Member Report Posted August 7, 2022 Draw a grid to suit the 9 point spi ? Quote Al speling misteaks aer all mi own werk..
Members thekid77 Posted August 7, 2022 Author Members Report Posted August 7, 2022 hi Fred, that actually is a 9 point spi grid - the tines on the chisel do not line up to it.... that's the issue that I'm having unfortunately Quote
CFM tsunkasapa Posted August 7, 2022 CFM Report Posted August 7, 2022 It is probably metric. Quote Hoka Hey! Today, tomorrow, next week, what does it matter?
Contributing Member fredk Posted August 7, 2022 Contributing Member Report Posted August 7, 2022 On 8/7/2022 at 4:39 AM, fredk said: Draw a grid to suit the 9 point spi ? Expand Draw a grid to match the 9 spi chisels that you have Quote Al speling misteaks aer all mi own werk..
Members mdawson Posted August 7, 2022 Members Report Posted August 7, 2022 On 8/7/2022 at 4:51 AM, tsunkasapa said: It is probably metric. Expand Looks like it's a 3mm spacing. Quote
Members Leescustomleather Posted August 8, 2022 Members Report Posted August 8, 2022 The chisel has 10 tines not nine that is your problem Quote
Members thekid77 Posted August 8, 2022 Author Members Report Posted August 8, 2022 thanks everyone for the help....i realized that my issue was that I had always laid my patterns out on an 8 spi grid, which works because inches divide evenly into eighths......not so w 3mm..... so I just needed to work on a 3mm grid.....now everything lines up perfectly... again, thank you so much for your help, everyone who took time to read and reply....I appreciate it!! Quote
