Members YinTx Posted August 20, 2022 Author Members Report Posted August 20, 2022 5 hours ago, chuck123wapati said: Darn good tooling you did an amazing job its very nice work i cant do letters lol. On your question a welt in a knife sheath is to protect the stitching it doesn't have to be an inch thick to fit the guard that's not what its intended purpose is but like all things hand made you can make it as thick as you want and i wont tell you your wrong by doing so. I make my welts the blade thickness at the most. Now on holsters i make a short tapered welt ,sometimes, because a revolver cylinder is much wider than the barrel but even those aren't an inch thick. I'll try one like you mention. I did it that way to keep the guard from rubbing on the belt tunnel section, and to keep it from pushing into the belt loop/tunnel section towards the rear, which I thought might cause binding when sheathing/unsheathing the blade. Maybe I am over thinking things. The blade welt is only the thickness of the blade, (which was around 11 oz on this blade) but I added tapered welts to manage the guard width. Thanks for the suggestions, and compliment! 6 hours ago, Leescustomleather said: I put down some smooth soft wood like fir or pine and move it with the leather Makes sense, I'll give it a go. YinTx Quote YinTx https://www.instagram.com/lanasia_2017/ https://www.youtube.com/playlist?list=PLK6HvLWuZTzjt3MbR0Yhcj_WIQIvchezo
Members doubleh Posted August 20, 2022 Members Report Posted August 20, 2022 (edited) I drill my holes first to give me a straight stitch line on the back. Then I use the awl. Sick it in a piece of bee's wax to make the needle go, push it thru the drilled hole and stitch. You won't be able to tell there was any drilling done and it surely lessens the effort of pushing the awl. Edited August 20, 2022 by doubleh Quote
Members Leescustomleather Posted August 20, 2022 Members Report Posted August 20, 2022 2 hours ago, YinTx said: I'll try one like you mention. I did it that way to keep the guard from rubbing on the belt tunnel section, and to keep it from pushing into the belt loop/tunnel section towards the rear, which I thought might cause binding when sheathing/unsheathing the blade. Maybe I am over thinking things. The blade welt is only the thickness of the blade, (which was around 11 oz on this blade) but I added tapered welts to manage the guard width. Thanks for the suggestions, and compliment! Makes sense, I'll give it a go. YinTx When accommodating a guard that large I will make the belt loop a separate piece, and then make a spacer from a couple of thicknesses of 9-10 oz Vegtan with the beltloop as the outer most piece and attach it that way. Love your work!!! Quote
Members YinTx Posted August 20, 2022 Author Members Report Posted August 20, 2022 2 hours ago, Leescustomleather said: When accommodating a guard that large I will make the belt loop a separate piece, and then make a spacer from a couple of thicknesses of 9-10 oz Vegtan with the beltloop as the outer most piece and attach it that way. Love your work!!! Thanks! Can you show a pic of what you are describing? YinTx Quote YinTx https://www.instagram.com/lanasia_2017/ https://www.youtube.com/playlist?list=PLK6HvLWuZTzjt3MbR0Yhcj_WIQIvchezo
Members YinTx Posted August 20, 2022 Author Members Report Posted August 20, 2022 2 hours ago, doubleh said: I drill my holes first to give me a straight stitch line on the back. Then I use the awl. Sick it in a piece of bee's wax to make the needle go, push it thru the drilled hole and stitch. You won't be able to tell there was any drilling done and it surely lessens the effort of pushing the awl. What size drill do you use? I did have to wax my awl a couple of times, and strop it, both of which I pretty much never have to do. YinTx Quote YinTx https://www.instagram.com/lanasia_2017/ https://www.youtube.com/playlist?list=PLK6HvLWuZTzjt3MbR0Yhcj_WIQIvchezo
Members dikman Posted August 20, 2022 Members Report Posted August 20, 2022 Very nice work, the leaf on the back, being so large, looks a bit like a feather to me (?) but the shading on it is very subtle, it looks great. When I got my arbor press I made a few odds and ends for it, one of them was to mount an awl blade in a fixture so I could use it for precisely your problem, thick welts. Never used it 'cos not long after I bought a Cowboy 4500. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members doubleh Posted August 21, 2022 Members Report Posted August 21, 2022 (edited) 2 hours ago, YinTx said: What size drill do you use? I did have to wax my awl a couple of times, and strop it, both of which I pretty much never have to do. YinTx I use a 1/16" bit. I got the bee's wax trick from a bootmaker I was friends with long ago. Stick the awl in the wax on every hole. It isn't to ease the awl, it's to make the thread needles go easier. I profile my awl needles with a fine tooth file to get a true diamond shape, smooth them down with a fine diamond hone, polish them with 600 and 1000 grit wet or dry paper, and then strop them. Your hand and arm will thank you. Eventually you will need to re-do the point on the blade. Edited to add: I forgot to mention that you did a great job on the sheath. Edited August 21, 2022 by doubleh Quote
Members YinTx Posted August 21, 2022 Author Members Report Posted August 21, 2022 3 hours ago, dikman said: Very nice work, the leaf on the back, being so large, looks a bit like a feather to me (?) but the shading on it is very subtle, it looks great. When I got my arbor press I made a few odds and ends for it, one of them was to mount an awl blade in a fixture so I could use it for precisely your problem, thick welts. Never used it 'cos not long after I bought a Cowboy 4500. If it only slightly resembles a feather, I guess I can't claim success. It is supposed to be a feather... same as the decorations on the front are feathers. If I ever get enough confidence in my Techsew, I'll use it. Spent a couple of hours cajoling, cursing, sweet talking etc to it, and managed to get it to sorta sew a belt. Certainly won't be using it on something with as many hours into it as this sheath! YinTx Quote YinTx https://www.instagram.com/lanasia_2017/ https://www.youtube.com/playlist?list=PLK6HvLWuZTzjt3MbR0Yhcj_WIQIvchezo
Members Leescustomleather Posted August 21, 2022 Members Report Posted August 21, 2022 (edited) 5 hours ago, YinTx said: Thanks! Can you show a pic of what you are describing? This is just a mock-up done with scrap leather, but I think you can get the idea. It also minimizes the beltloop contact with the knife handle YinTx This is just a mock-up but I think you can get the idea, it also minimizes contact of the knife handle with the beltloop Edited August 21, 2022 by Leescustomleather Quote
Members YinTx Posted August 21, 2022 Author Members Report Posted August 21, 2022 @Leescustomleather, If I see that right, you would only be stitching through 5 layers for the belt loop to sheath back, then 3 or so layers for the back, welt and front? Seems like a decent way to do it. I'll keep it in mind for the next one. Thanks! YinTx Quote YinTx https://www.instagram.com/lanasia_2017/ https://www.youtube.com/playlist?list=PLK6HvLWuZTzjt3MbR0Yhcj_WIQIvchezo
