Members krummark Posted September 7, 2022 Members Report Posted September 7, 2022 I want to start out and say I have little to knowledge of plough gauges and no experience with them at all. But I do have the chance to pick one up from a local guy who got some tools from a friend. Looking at the plough guage, both sides of the blade are beveled, and correct me if I'm wrong, but from my understanding only one side should be beveled. Does having both sides beveled ruin the blade? Is it fixable? If so, how intensive would that be? They were asking like $200 for it, if that is a defective blade, is it even worth it anymore, if it still a good tool would it lower the price? Looking forward to learning about plough guages here. Quote
Members Simplejack1985 Posted September 7, 2022 Members Report Posted September 7, 2022 Just post the brand here and old boys contact info. We can just order a new knife for it from a few different aftermarket makers. 200 is a steal bro Quote
Members TomE Posted September 7, 2022 Members Report Posted September 7, 2022 (edited) You're correct that the knife blade should have a single bevel facing the guide and a flat backside. This setup pushes the leather strap against the guide. The knife might be repaired by taking the edge back to where the backside of the knife is flat and the front has a gradual taper of less than 20 deg. It depends on how much bevel has to be removed and how much blade is left. The tip of the blade should be positioned at or near the trailing side of the ruled bar that the strap slides across. If the plough gauge is an old Blanchard or Dixon in working condition, I think the frame alone is worth $200. They are hard to find and you could have a knife made for the frame. Edited September 7, 2022 by TomE Quote
Members krummark Posted September 7, 2022 Author Members Report Posted September 7, 2022 Thanks for the replies guys. I am curious now though, how much would a replacement blade cost for the frame? It's an old H. Brindley plow gauge if that brand makes a difference or means anything. Quote
Members jcuk Posted September 7, 2022 Members Report Posted September 7, 2022 H. Brindley lovely old tools i have an old Martingale groover and a Skirt Shave (French edger) both great tools to use both over a century old still going strong. Tom E is correct it should have single bevel, i would and see how its works anyway if not try and get someone to correct it for you maybe you can that or get some who maybe able do it for you, if not here is a couple of links for a new knife for it just contact them to be on the safe side to if it will fit. I do know a saddler friend who replaced his old Dixon Plough Gauge Knife with one of these. https://gandmtools.co.uk/product/george-barnsley-cornish-works-sheffield-saddlers-plough-knife-80211994/ https://www.georgebarnsleyandsons.co.uk/product-page/plough-gauge I would check with George Barnsley if it was me. Hope this helps JCUK Quote
Members jcuk Posted September 8, 2022 Members Report Posted September 8, 2022 By any chance is this the one. https://www.ebay.co.uk/itm/195334770516?hash=item2d7adc0f54:g:DnwAAOSwXbJjD-Qy&amdata=enc%3AAQAHAAAAoKvSRHRPz8tCY%2B9BT3h97Zg0dTTj1lvqE1VosTokfWNj25Ax1dvak9eUwTvboI3owVDlbuBhIMfBmk1%2FERHDwplfg4Cc90jMLEw0sU95Ec1Cr5fw%2FX0EztOKTpYV5yxqdo9eFsbxTjwoPQWIET75XFvAaORpX1veZ78994ptllniQEXBaV3qjwnApl12CBTW3IGEqGgECLqjF0%2B29jjtqcw%3D|tkp%3ABk9SR-rn5eTjYA Quote
Members krummark Posted September 8, 2022 Author Members Report Posted September 8, 2022 No it's some old local guy here in Juneau, AK, but that does look similar. That one also looks like both sides of the blade are beveled, coincidence? Thankyou for sending those links by the way. I know some blacksmiths in town who might be up for that job, I'm not sure though. Only having experience with sharpening knives and whatnot I don't know what all would go into reshaping a blade to have the correct bevel. Quote
Members jcuk Posted September 8, 2022 Members Report Posted September 8, 2022 The marking on the one in the link are M.O.D. all i can say to i would take a punt on it if was me. I am sure someone on here with experience of regrinding/reshaping edges (not my field that kind of stuff scares the hell out me) will tell if it could done. Hope this helps JCUK Quote
Contributing Member fredk Posted September 8, 2022 Contributing Member Report Posted September 8, 2022 What jc means is that the arrow marking on the parts of that plough gauge is the 'Tower of London' UK Ministry of Defence marking. Everything made for the MoD and approved is marked with that arrow Quote Al speling misteaks aer all mi own werk..
Members dikman Posted September 8, 2022 Members Report Posted September 8, 2022 If the blade is similar in size to the one in the link it should be possible to re-grind the blade. A belt grinder would be best but an angle grinder should work, just take it slow and keep cooling the blade. Finish off with oilstones/waterstones. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
