Members HDavy Posted November 2, 2022 Members Report Posted November 2, 2022 I just purchased an Adler 30-1 and have a few questions on set up and adjustment who can help me? 1 what is the best source for info /videos, there aren’t very many on YouTube 2 source for parts ? Thanks Davy Quote
Moderator Wizcrafts Posted November 3, 2022 Moderator Report Posted November 3, 2022 4 hours ago, HDavy said: 2 source for parts ? Try our members @CowboyBob at Toledo Industrial Sewing Machines, or @shoepatcher. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Ole South Posted November 3, 2022 Members Report Posted November 3, 2022 I've got one (long arm, don't know if a short arm was made)... done some work on it. Parts other than those in common with 29K are virtually nil. I did find some Adler decals though. It's a much nicer machine than 29- series and I do like it better than most 29k small bobbin machines. Info is in short supply but if anyone has it Constabulary will. In my experience it makes a nicer stitch and sounds and feels like a Mercedes vs a '62 Ford sedan compared to the Singer Patchers. Prolly the only reason I still have mine AND a Singer 29k60 (long arm, big bobbin). (and no... you can't date the machine by Serial Number unfortunately) Quote
Members shoepatcher Posted November 3, 2022 Members Report Posted November 3, 2022 What color is he machine? I can give you a rough age based on the color. If you are looking for the knurl screw that you can lock the butterfly from turning, it is called a stop screw. I need the color of the machine to see which one it needs. i may have some. glenn Quote
Members Ole South Posted November 3, 2022 Members Report Posted November 3, 2022 Don't know who's looking for a Stop Screw but my 30-1 appears to have a small (compared to a 29k) collared and knurled M5 1.0 (near as I can tell, does that indicate an approximate date?) Stop Screw. Unfortunately, the machine looks to have been stripped and repainted a semi-flat black and no Decals. Cast iron, not wooden treadle. Quote
Members HDavy Posted November 3, 2022 Author Members Report Posted November 3, 2022 12 hours ago, shoepatcher said: What color is he machine? I can give you a rough age based on the color. If you are looking for the knurl screw that you can lock the butterfly from turning, it is called a stop screw. I need the color of the machine to see which one it needs. i may have some. glenn Green it’s a light greenish color! I’ll send you a picture Quote
Members HDavy Posted November 3, 2022 Author Members Report Posted November 3, 2022 12 hours ago, Ole South said: I've got one (long arm, don't know if a short arm was made)... done some work on it. Parts other than those in common with 29K are virtually nil. I did find some Adler decals though. It's a much nicer machine than 29- series and I do like it better than most 29k small bobbin machines. Info is in short supply but if anyone has it Constabulary will. In my experience it makes a nicer stitch and sounds and feels like a Mercedes vs a '62 Ford sedan compared to the Singer Patchers. Prolly the only reason I still have mine AND a Singer 29k60 (long arm, big bobbin). (and no... you can't date the machine by Serial Number unfortunately) Thanks for the info Quote
Members HDavy Posted November 4, 2022 Author Members Report Posted November 4, 2022 23 hours ago, shoepatcher said: What color is he machine? I can give you a rough age based on the color. If you are looking for the knurl screw that you can lock the butterfly from turning, it is called a stop screw. I need the color of the machine to see which one it needs. i may have some. glenn Thanks Glen I’d definitely be interested in one if you do! Quote
Members HDavy Posted November 5, 2022 Author Members Report Posted November 5, 2022 23 hours ago, HDavy said: Thanks Glen I’d definitely be interested in one if you do! Quote
