Made this for my mother.  I hope she will beat it up and really test it’s durability.  She had been stealing my stepdads backpack for rockhounding outings so I made this for her for Christmas.
8 minutes ago, chuck123wapati said:
that is awesome!!
Thank you!
Now I have a crick in my neck after leaning so far over to view the sideways pictures. None the less it is good work and should stand up to it's job.
Edited by doubleh
 Thank you!
Haha, yeah I guess formatting on the forum vs the orientation of the photos when I took them didn’t translate well.
My head won't tilt that far so I hope you don't mind . Very nice work :spoton:
looks like I have hit the ole 1.46 wall ......... I'll try again in a little while
down sized just a bit
Good work. I built a one of his travel bags.
  • CFM
I think the bag is outstanding and a good job.   I have mad a few packs and my Bud also makes packs I would  like to give you a couple of ideas for your next pack.
again nothing wrong with your back pac. I like it!!
I have found that the flap top of your bag type will tend to leak in the morning when the dew melts and the contents get wet
my Bud Gary cam up with a solution that allows the content to stay dry but adds space to the sq footage of the pack itself
instead of the flap, make the tubular or square sharp of the pack longer then you  use a draw string to close and roll the top
of the bag closed
then use 2 straps one on each side of the roll to secure roll top closed
the loose ends of the straps bug me, so below the buckle make a pouch to slide the excess into
This is not my bag, Gary made this it is a roll top as mentioned with double straps and end strap pouches
the image is turned the correct way in my computer way up with the site
Very nice, and should hold up to abuse well.
