CFM Frodo Posted January 21, 2023 CFM Report Posted January 21, 2023 Last week I had to cut the needle bar out of this machine with a dermal. Ordered new parts from Bob rr at Toledo sew machine sales The parts game in and I started putting the machine together while having an eye out for any parts that may be damaged, This machine sat outside in a shed for years everything was going fine till I noticed the v walking foot guide bar was not lifting when it walked nor did the lifting handle budge it. So I took the parts out to have a look. Guide bar seems to be ok just dirt cleaned oiled and started to reassemble the whole machine is jammed up. I looked inside where I was working and no tools or parts were left inside what would cause this? Before dismantling it was freely moving 69603650968__AA4CA708-5940-43FA-BDF5-E840457BFDAA.MOV Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
CFM Frodo Posted January 21, 2023 Author CFM Report Posted January 21, 2023 Found it, old needle gel into the hole and jammed it up Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
CFM Frodo Posted January 22, 2023 Author CFM Report Posted January 22, 2023 Walking foot lift lever what would keep this assembly from not working? please excuse the dirty hand, When you play with oil you get dirty 69603948068__57580C34-F105-4928-835A-34FFA2C390D5.MOV Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
CFM Frodo Posted January 22, 2023 Author CFM Report Posted January 22, 2023 With the foot tension adjustment knurl bob all the way down, I can get the foot to walk still no lift on the foot raise bar assembly suggestions ? 69604116814__524DFCA2-AFB0-40FB-85B6-AC5923327635.MOV Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
CFM Frodo Posted January 22, 2023 Author CFM Report Posted January 22, 2023 this is interesting the lock nut on the tension adjustment when in the locked position is in the way of the foot bar guide as you can see in the picture Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
CFM Frodo Posted January 22, 2023 Author CFM Report Posted January 22, 2023 I am leaning towards 1 of 2 things Rusted or bent the guide bar for the walking foot any professional opinions ? I am just a plumber, and do not know squat about what I am doing Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
CFM Frodo Posted January 22, 2023 Author CFM Report Posted January 22, 2023 Come on guys, please! I can not do it with out you !!!! Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
Moderator Wizcrafts Posted January 23, 2023 Moderator Report Posted January 23, 2023 My only input, being unfamiliar with your machine, is that you need to find out where the adjuster is that lets you lower the position of the inside foot. The dropping of the inside "vibrating" foot causes the raising of the presser foot. If the inside foot doesn't make firm contact with the throat plate, and maintain it, the outside foot cannot lift. On a Singer 111 type machine there is a crank coming out the mid-back that connects to a knuckle joint that is adjustable in a curved slot to adjust the amount of lift. There is a large screw on the knuckle that when loosened lets me move the inside foot up or down., then lock it in. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Constabulary Posted January 23, 2023 Members Report Posted January 23, 2023 (edited) Videos are blurry and shaky and do not show "the whole scene". Anyway - as far as I can tell you have installed the needle bar and needle holder incorrectly and the needle clamp screw probably blocks the foot when lifting the foot lever. With other words rotate the whole needle bar until the clamp screw faces right. But I only can guess here. Edited January 23, 2023 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Quade Posted January 23, 2023 Members Report Posted January 23, 2023 On my singer, what I call the primary foot, the one on the back, the shaft has two clamps attached to it. One clamp is for the spring that's on the back of the machine which creates the primary tension for the presser foot and the other is what the hand lift presses on to push the primary presser foot shaft up. I'd probably take off the both presser feet. Unscrew the tensioner thing on the top back, Then see if you can get that rear shaft to lift up and down. You ought to be able to release the clamps and pull it out of the top of the machine but, I wouldn't do that initially. The question is where there's a mechanical jam or if the shaft itself is stuck. When you press up on the hand lift, the inner and outer feet should both lift up. Either one could block you. I don't know that machine so, I can only guess. I have a feeling the problem is in the thing that moved the feet but that's just a guess. Quote
