Members Edsbear Posted March 21, 2023 Members Report Posted March 21, 2023 Hi, My Brother LS2-B837 won't reverse into the same holes, the reverse stitch is smaller. I have adjusted the reverse lever stop to make a bigger stitch but this doesn't make any difference. Does anyone know if there is something else to adjust to balance the stitches Many thanks Quote
Members Handstitched Posted March 21, 2023 Members Report Posted March 21, 2023 Thats been on here a few times. try this : https://leatherworker.net/forum/topic/106927-help-with-singer-211g166/?tab=comments#comment-709444 Also @Wizcrafts may be able to help . HS Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
Members Quade Posted March 22, 2023 Members Report Posted March 22, 2023 The manual for my machine, a singer 211, mentions that some models have unequal forward and reverse stitch length by design. There's a limiter bracket installed on the reversing arm which limits both the forward stitch length and reduces the reverse stitch length. There's still an adjustment that would normally be used to equalize the stitch length on the arm that drives the feed dog shaft. Your machine is different than mine but there's typically an adjustment on the stitch length mechanism to equalize forward and reverse stitches. Quote
Members Edsbear Posted March 22, 2023 Author Members Report Posted March 22, 2023 Thanks Quade, I have adjusted the reverse lever stop to make a bigger stitch but this doesn't make any difference. Still not the same as forward. I still cant find the adjustment to equalise forward and reverse stitch length Quote
Moderator Wizcrafts Posted March 22, 2023 Moderator Report Posted March 22, 2023 I was able to equalize the forward and reverse stitch length on my 211g156. I adjusted a cam on the lower shaft, but don't recall which one. But, the maximum length became 5 stitches per inch in both directions. If you have fiddled with the cam that is supposed to balance the forward and reverse and can't get close to 5 to the inch, something else has to be worn out or loose. Check the feed dogs and the fork they mount on. Check the slop on the bottom shaft itself. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Quade Posted March 23, 2023 Members Report Posted March 23, 2023 Quote I was able to equalize the forward and reverse stitch length on my 211g156. I adjusted a cam on the lower shaft, but don't recall which one. But, the maximum length became 5 stitches per inch in both directions. The arm on the left hand side there with the slot in it. I believe that's how you equalize the stitch. You have to loosen some set screws to allow it to turn. I'd really recommend reading the manual. Quote
Members Edsbear Posted March 23, 2023 Author Members Report Posted March 23, 2023 The base of my Brother B837 looks a bit different to the 211g156 but there must be something similar to adjust but cant see which bit Thanks everyone Quote
Members Quade Posted March 24, 2023 Members Report Posted March 24, 2023 That center shaft is what changes when you put it in reverse. You can see the linkage on the right side. I'm not clear how it works on this machine. Quote
