Members Leatherguy123 Posted May 30, 2023 Members Report Posted May 30, 2023 The seamstick or basting I have for my polyester webbing will not stick to it. Sticks to my leather and vinyl no problem, but the polyester webbing I have it wont even phase it...is there a special basting tape for polyester webbing I should be using? Quote
Members Handstitched Posted May 30, 2023 Members Report Posted May 30, 2023 Never used it before , but hemming tape thats used on fabrics may be used, but its used with an iron , perhaps on a low setting? Or, Tenacious Tape, a peel and stick type tape for making repairs. Theres also Kikusui 190 Seamstick tape , holds stuff down while sewing. HS Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
kgg Posted May 30, 2023 Report Posted May 30, 2023 8 hours ago, Leatherguy123 said: Sticks to my leather and vinyl no problem, but the polyester webbing I have it wont even phase it...is there a special basting tape for polyester webbing I should be using? How how thick and rough is the surface of the polyester webbing. I ran across this problem when I tried to use a thick very knobby webbing. The basting (double sided) tape needs surface contact so the smoother the two surfaces you are trying to connect the better particularly with smaller widths of basting tape. You could try regular heavy duty double sided tape or gluing the webbing in place but the downside maybe those may gum up the needle. A photo of the webbing may help with what's going on. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Leatherguy123 Posted May 30, 2023 Author Members Report Posted May 30, 2023 It's a very light duty webbing, almost like ribbon for wrapping paper. It's for reinforcement on a French seam. Trying to figure out a way to make it stick so it doesn't wander on me. Quote
Contributing Member fredk Posted May 30, 2023 Contributing Member Report Posted May 30, 2023 For that sort of need I just use ordinary thin (black) material and glue a cut piece on Quote Al speling misteaks aer all mi own werk..
Members nylonRigging Posted May 30, 2023 Members Report Posted May 30, 2023 17 hours ago, Leatherguy123 said: The seamstick or basting I have for my polyester webbing will not stick to it. Sticks to my leather and vinyl no problem, but the polyester webbing I have it wont even phase it...is there a special basting tape for polyester webbing I should be using? Basting Tape not sticking very well, or loose bonding to Webbing Poly's, Urethane's, Nylon . Thinner Synthetic fabrics it does well and strong till it stitched, but on the heavier weight weave of webbing's it does Not hold very long for waiting around to get sewn. The Basting Tape after pealing off the backing is 'ultra-thin' so it really only meant for thin light materials seam fold . ( Me ) , This----> if I got a layers of any 'heavy materials' that need to be held firm and strong for critical placement. I will sometimes use a dab of Silicon Stick, Hot Glue Gun, it holds firm, the Silicon stick is soft, Needles and thread easy go threw the Silicon for stitching after cooling . Heavy wraps/folds/layers hot glue gun works great, been doing it for many years. . Quote
