Members LzCraft Posted June 4, 2023 Members Report Posted June 4, 2023 As the title says, am I supposed to glue the lining over the stiches for the bullet loops or stitch through the lining? I've seen both done. I'm assuming glued over stitches are more resistant to wear, while a stitched through construction is much easier to repair. Belt: 10-11 oz. Heavy veg tan Liner: 6-7 oz. Veg tan Loops: 4-5 oz. Veg tan Thread: 18/6 Waxed linen thread Method: Saddle Stitch Quote
Contributing Member fredk Posted June 5, 2023 Contributing Member Report Posted June 5, 2023 I think it comes down to 1. personal preference 2. aesthetics 3. can you sew through at least 8mm of leather, assuming the loop leather is on the outer surface of the main belt If the stitches are on the outside of the inside of the belt they might be subject to more wear whereas if they under the lining the thread is protected Why sew at all? Punch slots on the main belt and weave the bullet loop leather through the slots. Do it wet and the loop leather will dry to shape and stay in place. Then you only need a couple of stitches or a rivet at each end of the bullet loop strip Quote Al speling misteaks aer all mi own werk..
Members LzCraft Posted June 5, 2023 Author Members Report Posted June 5, 2023 1 hour ago, fredk said: I think it comes down to 1. personal preference 2. aesthetics 3. can you sew through at least 8mm of leather, assuming the loop leather is on the outer surface of the main belt If the stitches are on the outside of the inside of the belt they might be subject to more wear whereas if they under the lining the thread is protected Why sew at all? Punch slots on the main belt and weave the bullet loop leather through the slots. Do it wet and the loop leather will dry to shape and stay in place. Then you only need a couple of stitches or a rivet at each end of the bullet loop strip Yes, laced loops are easier to make and more durable than stitched loops. However, when looking at surviving examples of cartridge belts from 19th Century America, the loops are mostly stitched. I personally have never seen an authentic ranger style belt with laced loops. Many belts then were unlined, but when looking at lined examples, they show that both stitch through and glue in were done. Of course there was also the money belt, which I guess is "folded in". Quote
Members Dwight Posted June 5, 2023 Members Report Posted June 5, 2023 I've read of different accounts . . . even one where the guy had laced loops and no lining . . . they were loose . . . if he took out a few and took off his belt . . . the rest of the bullets fell on the ground . . . . it was laced so loose. I've sewn and laced . . . gave up sewing . . . laced ones are far more accurate and I think they look better. Customers get laced or go somewhere else. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members BigBore Posted June 5, 2023 Members Report Posted June 5, 2023 Personally, I’d stitch through both in case a repair is needed one day and it creates a better bond between the two. For me, I’ve gone to lacing the loops with a small ‘tack stitch’ between each loop. I’ll either stitch between or use a rivet. This eliminates the issues with looseness when multiple cartridges are removed. Quote
