What about other knives? Anyone use others? My favorite is one I made while working in the saddle shop. I copied the one Charlie Miller had made and used for just about everything. It does more than most.
  • Replies 22
  • Created
  • Last Reply
Top Posters In This Topic
10 hours ago, Frodo said:
I love the round knife
Are you familiar with a hand wood plane?
can you shape a mini round knife using a 2” wide blade  from the plane
Yes, you could make one. Here's the problems I see. Plane blades tend to be thicker and would be a lot of metal to remove to make a decent kind of knife. Two inches wide is really narrow. When a round knife gets down to 3-1/2 to 3 inches it looses a lot of function in my hands - too little finger clearance., limited rolling cut length before you get close to vertical with the handle for a couple quick things against them. I used a 3" knife for a while and finally just garbaged it. It wasn't  as safe or effective for me as a larger blade. There was no advantage to it.
Bruce Johnson
Malachi 4:2
  • CFM
Frodo you might be able to pull off a half round blade, I'm with Bruce on the size, or use the plane blade sideways and weld on a piece for the handle.
  • CFM
You are correct on the thickness. It takes a lot of patience to remove that amount of metal and keep it cool
the blade on the left is the best cutter
Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles
D.C.F.M
Yep, this is mine.  Fits in my hand nicely, replacement blades are easy to change, and  cheap as, but I also sharpen the old ones on a stone to extend their life.  I also use it to score the skin on a roast Pork :yes:
' I have a very gweat friend in Wome called Biggus Dickus,
He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '  :rofl:
  • CFM
i made one similar out of a good quality putty knife then upgraded a bit and made a better model  when i found i like the shape
  • CFM
1 hour ago, MarshalWill said:
That new one is beautiful. Certainly a step above the putty knife. Is it sharpened on one side or both equally?
they are both chisel edged, sharpened one side.
Nice work on the knives, Mr. Johnson. I have never warmed up to using a round knife for some reason. Color me weird I suppose as it seems to be a favorite of many.
Thanks. It looked that way but I wanted to verify that.
