I have yet to get any notification of replies to threads I've posted in or want to follow. I have checked these points in 'Notification Settings':
  • Quote
    • Automatically follow content
      • Automatically follow new content I post
      • Automatically follow content I reply to
    • Method to use for content I follow automatically
      • A notification when new content is posted
    What gives? I must have some setting wrong but darned if I can figure it out. I remember this from the first time I was on the forum and eventually I just stopped checking. There are some outstanding forum members here but this makes me less apt to participate. I'm back to give it another try so any suggestions are most welcome. Thanks.
This works for me.  Maybe you need to check the box for "send me news and information" to get on the mailing list.  Not sure why your selections don't work.  If adding this check box doesn't work, we'll have to get @Johanna  to look at it.
Also at the bottom of the screen, you can set "notify me of replies" if it isn't already set before you submit any post.
Thanks. I'll give that a try. Will post back if that works.
Edit: I just checked and that option is already chosen.
Edited by MarshalWill
I never get notifications, I never have. I just check through the forum to see what I'm missing
If notifications are not possible, if I could search by new content to threads I'm following that would help. Right now, I'm still bungling around trying to figure out how the software for this forum works. I'm a moderator on two other forums but this one doesn't work the same.
I have tried following the links at the top of the page under 'Activity' > 'My Activity Streams' > 'Unread Content', 'Content I Follow', 'Content I've Started', and 'Content I've Posted In'. but there seem to be a lot of other threads included in those searches. Is there one link that will just list new content to threads I follow?
Setup your own stream.  Here is one that looks for all new content in the past 7 days.
Adjust the selections under Following.  You can follow areas, members, or content items I follow.  Save your 'stream'.
Reach out to @Johanna to see if she can fix your notifications.  She has for others.
Thanks for the reply, Northmount. I set up a stream as you suggested. I don't understand what it means, but it's there. I attached the page for it. If that doesn't do what I need, I'll contact @Johanna. I may do that anyway.
