My guess is it's how you're cutting it and it's unavoidable. Strap cutters the leathers pulled straight through a vertical blade vs. pressing down and pushing or pulling a blade on the straight edge and the leathers stretching and getting it offline. I gave up on trying to get it straight and now use a straight edge and a pencil then cut the line instead of trying to cut against a straight edge.
15 hours ago, HondoMan said:
What is being overlooked folks, is that it is always...again always the middle mark.  The marks to the left and right are always spot on.
That is because you put your edge against the two outer marks. Two points define a line (basic geometry). If you aligned your straight edge with an outer mark and the middle one, then the second outer mark would be off.
As for why the three marks don't line up, I have no idea. It has happened to me, but then I manage to make all measuring errors known to mankind and invent a few of my own...
  • CFM
On 8/25/2023 at 2:30 AM, Handstitched said:
**Other people will have different methods to start a straight edge .
HS
i use a chalk line lol.
  • CFM
are you using something like this? How do you ensure that the edge your marking off of is straight and remains straight during the process?
  • CFM
When you cut the edge the idles edge stretchfed
when the event happens again that you described, check the edge that you measured from. The center of your cut has stretched on you when you cut it
Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles
D.C.F.M
  • CFM
When you use a metal straight edge the leather under the straight edge can move
it has been my experience that the middle portion of the straight edge does not get enough weight pressed in it
I personally am guilty on not pressing down in the center myself.  Buy a c-clamp
D.C.F.M
I have one of those :specool: Nowhere near as nice as that one. Made it in high school...way back when....:whistle: Our wood work teacher had one finger missing  ....good promo for wood work . So damn funny every time he pointed at us though,.... got some mileage out of that ,     LOL :yes:
HS
' I have a very gweat friend in Wome called Biggus Dickus,
He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '  :rofl:
  • CFM
Maybe you don't pull the ends as tight as the center when measuring. If you pull the center tighter and compress the leather a bit then when the leather relaxes back straight the scribe mark is farther from the edge or seemingly longer.
