Members PlanoMike Posted September 13, 2023 Members Report Posted September 13, 2023 Im making a purse from a pattern. it's a round purse. I used a 5mm, 2 points Japanese stitching iron to punch the gusset and round front & back for the round purse. The purse measurements are metric, and I matched the pattern exactly. I go around the front & back pieces 5mm from the edge punching the stitching holes. I am very careful to be precise with my punching. I then punch the holes in the gusset( which goes around the entire purse) using the same iron at 5mm from the edge. I come up with exactly the same number of punches for both gusset and front & back pieces. And the punches start and end exactly where they are supposed to. So now I feel confident and start stitching from the center of gusset and front piece. I notice as Im stitching that the holes on the round front piece are gaining distance from the punches on the gusset. They are supposed to be directly across from one another. In fact the holes get several holes apart from one another. thus the stitches are all out of alignment and the project locks like crap. What am I doing wrong that the punch holes don't stay aligned across from on another? I do a lot of hand stitching and am pretty good at it. Ive successfully stitched square bags with large rounded corners with no problems.Im lost. Help Please. Thanks, Mike Quote
Members PlanoMike Posted September 13, 2023 Author Members Report Posted September 13, 2023 I failed to mention at the start im making a round purse, 20cm diameter(front and back pieces), and 7cm wide gusset. Quote
Members zuludog Posted September 14, 2023 Members Report Posted September 14, 2023 I can't help you, but this might Quote
Members Tugadude Posted September 14, 2023 Members Report Posted September 14, 2023 Best thing is to show us. The way you describe the situation makes little sense to me based on this phrase: 12 hours ago, PlanoMike said: In fact the holes get several holes apart from one another. thus the stitches are all out of alignment and the project locks like crap. I can imagine a hole apart, but two? Or more? Can’t see how that could physically happen. Quote
Contributing Member fredk Posted September 14, 2023 Contributing Member Report Posted September 14, 2023 Its because you have two circles of different diameters Quote
Members PlanoMike Posted September 14, 2023 Author Members Report Posted September 14, 2023 fredk Thank you. You are absolutely correct. I checked a couple other round bags that worked, but were assembled and stitched differently than the one I'm currently working on. Quote
Contributing Member fredk Posted September 14, 2023 Contributing Member Report Posted September 14, 2023 I used to get that mis-alignment problem with pre punched holes when I first made these; Problem solved by punching holes along outside edge of the front and back pieces but punching only one hole in each edge of the gusset, at centre bottom, for parts alignment, then using either double-sided tape or glue to hold the gusset in place and making sewing holes by using an awl, a few holes at a time, sewing up, then more holes and so on Quote
Members GrampaJoel Posted September 14, 2023 Members Report Posted September 14, 2023 (edited) 22 hours ago, PlanoMike said: I failed to mention at the start im making a round purse, 20cm diameter(front and back pieces), and 7cm wide gusset. I have found that occasionally a pattern that I have purchased from the internet won’t align up properly. I write it off as a poorly designed pattern, and move on. It can be a frustrating and expensive experience sometimes. Joel Edited September 14, 2023 by GrampaJoel Quote
