Members SpruceMoose Posted September 14, 2023 Members Report Posted September 14, 2023 I'm having trouble with my presser foot not walking up and over layers, I'm guessing a foot with teeth would fix this? I'm slipping often, and it's driving me nuts. thanks Quote
kgg Posted September 14, 2023 Report Posted September 14, 2023 1 hour ago, SpruceMoose said: I'm having trouble with my presser foot not walking up and over layers Knowing what machine would be helpful. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members KenH Posted September 14, 2023 Members Report Posted September 14, 2023 On my shoepatcher machine I made a presser foot with a smooth flat bottom. I glued 150 grit sandpaper to the bottom and that really feeds good now with no marks on the leather. Quote
Members SpruceMoose Posted September 14, 2023 Author Members Report Posted September 14, 2023 1 hour ago, kgg said: Knowing what machine would be helpful. kgg Techsew 2700, i know the parts number for the feet and such, easy to come by, I've got some extra presser feet and may modify them myself instead of buying more. I should say as well, I'm not talking about it not being able to climb an abrupt huge ridge of material, it just slips often on skived layers. Various materials, not just slippery leather. Quote
Members purplefox66 Posted September 14, 2023 Members Report Posted September 14, 2023 You need to adjust the height of the walking foot. Quote
kgg Posted September 14, 2023 Report Posted September 14, 2023 (edited) 1 hour ago, SpruceMoose said: I'm not talking about it not being able to climb an abrupt huge ridge of material, it just slips often on skived layers. Various materials, not just slippery leather. I would check a couple of things first before changing / modifying your presser feet: i) the height the feet dog protrudes above the needle plate. It maybe needs to be adjusted up slightly to bite into the bottom of the leather a touch more. ii) the position of the presser foot. Is it at the level of the needle plate or above? iii) the tension on the presser foot. If I'm not mistaken the Techsew 2700 is the same as the Cowboy 227R so this manual may help. kgg CB227R_Oper.Manual_print_pages_3-13.pdf Edited September 14, 2023 by kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Moderator Wizcrafts Posted September 15, 2023 Moderator Report Posted September 15, 2023 There are aftermarket feet with teeth. They are sometimes sold as zipper foot sets. I've bought them in left toe and right toe. The teeth are meant to grip zipper tape and get a good grip on leather. Just be prepared to rub out the tooth marks. There are also double toe feet with teeth that outdoor vinyl sewers tend to use. Vinyl is pretty slippery. Banners and boat covers are also sewn with toothed walking feet. Sailrite may stock the feet you need. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
