  • CFM
I went askew with the electric creaser when creasing a belt and was hoping the final length would be short of that blemish, but alas, it was within an inch of the tip.
Is there a way to smooth out that blemish or make it disappear? I'd really not want to cut the billet any shorter.
Thanks in advance for any helpful input.
I would try wetting it then take something really smooth and go back and forth gently over the crease .
A picture would help maybe. A double crease line possible?
  • CFM
As you can see, if I were to trim the end would be pretty much next to the hole—it'd probably look worse than the blemish:
In non-raking light, it's not too obvious, but it's still there:
This may be of some use to you, maybe try it on piece of scrap first. I have not tried this myself but it looks like it may help.
https://www.youtube.com/watch?v=b-Pa41ZUDNs
Hope this helps
JCUK
Its not too bad. I would bone slicker some pressure over the whole area and heavily redo the crease line as that should be able to pull the leather tighter into the groove area.
