So, as I got only a few photos to make certain bag (for the missus), does anyone have a pattern simmilar to this bag perhaps? Or can give me a hint or two on how to make a pattern for this kind of a bag?
Appriciate any help.
  • 4 weeks later...
I just took a bag the wife had and made it better. Measured it out and let her pick out some leather
Looks like it's just four panels with two functioning as gussets and underlapped with the front and back panel.  My guess is you can replicate the proportions by cutting four equal-sized rectangles and underlapping the edges, and pick the dimensions the missus would find useful.  I thought about doing something similar for a tote bag I'm making my mom for Christmas, but I decided my leather (~5 oz. S.B. Foote chrome tan boot leather) would be too bulky to make attractive overlapped seams.
  • 2 months later...
Expand
Thought of it aswell, but just can't figure out the cutouts on the side, without looking too robust.
Trying to get "about" the right pattern, before I can even modify it.
Expand
That’s going to depend significantly on what leather you use and what weight. That bag looks like pretty thin chrome tan, with a very shiny finish to it. Probably no more than 2/3 or 3/4 oz stuff. I’ll bet the leather is skived at the side cutouts to avoid creating bulk.
Expand
Vegetable tanned calfskin leather, 1.3-1.6mm thick (3-4 oz.).
  On 2/29/2024 at 7:18 PM, Mablung said:
Skive the edges well and you can probably keep the seam bulk to a minimum.
Expand
That doesn't seam (pun intended) to be much of a problem.
I'm more concerned about creating a pattern for this bag. Gives me shivers to even start.
Expand
Oh, I gotcha. I must have misunderstood what the real issue was.
It looks almost as though the main panels are wider at the top, like trapezoids. You might try using some heavy cloth or craft foam of a similar thickness to develop the pattern from trial and error.
Expand
Why not create a prototype with paper first?
The bag appears to be a very long rectangle forming the 2 main sides and the gussets being wider at the top (trapezoid) and stitched onto the main part to form a rectangular base. Once put together, the extra material on the trapezoid shaped gussets should form that fold  on each gusset naturally.
With paper, you can manipulate the width of the top of the trapezoid shape of the gusset to your  satisfaction and the base as well.  After that, translating into a leather bag should be simple.
NOTE:
I just made a prototype with paper and I apologize - it is not a trapezoid on the sides, it is a pentagon. Pics follow.
Edited by SUP
To correct earlier information.
Learning is a life-long journey.
This is the front of the prototype.
I cannot as yet upload the gusset pic. Will do so in a while.
Edited by SUP
No idea when I can upload the gusset shape  pic. My file size is small enough to remain below the limits.
Will try later today. Another appointment now.
Edited by SUP
That is the pentagonal gusset
@Mocivnik are you making that bag? Did this information help?
  • 2 months later...
Expand
It took me some time to actually make it, since I was quite busy lately. SO, today I've made it from scrap fabrics and it turned out....turned out great. So far so good, it needs quite some modificaitons (about dimensions mostly), but the design as itself looks great. Will keep this topic updated as my progress move on :)
@SUP: Your comments on shape were indeed on spot, it's the one! Thank you again, mister!
You're welcome.
Incidentally, it's Ma'am. Not Mister.:).
Edited by SUP
Looks a lot like a short duffel bag.
- Voltaire
- Aristotle
Actually, I think the whole body is cut from 1 piece of leather. Then the 4 corners are sewn up.
Look at the next to last picture and zoom in on the bottom. It almost looks like a seam going at an angle from left front (as you're looking at it) and going towards the right rear, but I think that's an illusion.
Imagine laying a piece of paper out and cutting a square from each corner so you can fold it up in to a box shape. I think that's all that's going on here.
- Voltaire
- Aristotle
