Members tothemew Posted January 26, 2024 Members Report Posted January 26, 2024 I know I'm a bit late to this party but, I've found that using 3M blue masking tape works pretty well at keeping the schmutz off the surface. Doesn't do much to stop the burns at the cut line but definitely simplifies the cleanup process. Depending on the surface finish of the leather, a little help from a blow dryer or a heat gun will help break the bond to remove the tape. Quote
Members RudolfNL Posted February 29, 2024 Members Report Posted February 29, 2024 On 12/17/2023 at 7:31 PM, ThomG said: Here is a before and after cleaning. it's still wet in the bottom picture that's why the color is so different. Uh-oh. that's soot. For less soot use a truncated nozzle and add a blower. Quote
Members Dwight Posted February 29, 2024 Members Report Posted February 29, 2024 On 12/15/2023 at 2:38 PM, ThomG said: Here is a sample, i cut both circles out of the material shown and cleaned one with the cleaner I'm talking about and not the other. Not meaning to pick on you Thom . . . but compared to my laser cutter . . . yours looks like it was cut with a chain saw. I use a little air compressor with my 5 watt laser . . . and one thing for sure I make is key fobs . . . I wipe the edges of em down with a terry cloth . . . and they are good to go. May God bless, Dwight Quote
Members ThomG Posted March 9, 2024 Author Members Report Posted March 9, 2024 Those were my first test cuts that didnt go through so i used a box cutter so i could test dyes etc. Quote
Members Cumberland Highpower Posted January 8 Members Report Posted January 8 (edited) On 12/17/2023 at 12:12 PM, Mablung said: Is that when cleaning with the pumice hand cleaner? I assume so but wanted to make sure I hadn't missed a change in tack in regard to cleaning. If so, that looks pretty good, as long as one doesn't mind any later finish being a bit matted due to the surface scratches. That looks great. Edited January 8 by Cumberland Highpower Quote
