How difficult would it likely be to restore the edge of a vintage C.S. Osborne round knife?  I found one on eBay that is quite old, so likely with the better steel of the old ones, and has a pretty dinged-up edge.  It's a good price, and while I'm pretty handy with a set of waterstones, I'm concerned the steel might be hard enough that I would have difficulty restoring it well and end up wasting my money.  I would be doing all the edge work by hand, as I don't have a grinder.
  • Replies 35
  • Created
  • Last Reply
Top Posters In This Topic
I dont think you will have a problem. It more elbow grease than anything in my eyes. Lol my arms are already tired.
I maybe totally wrong thou.
You can do it. Start on the rough side of an oil/water stone and work it down past the nicks.. When it's roughed in, change to the finer side of the stone and continue as you would any other knife, finishing up with whatever grits you normally use.
@bruce johnson will hopefully see this and share his expertise.
Thanks for tagging him.  Meant to and forgot.
I've got some pretty coarse grits I use to restore edges.  I redid the broken points on a couple knives made of O1 tool steel, some pretty tough stuff.  I guess in theory the high-carbon steel in the old C.S. Osborne knives can't be too much harder.
It might take a little more time to work it down but the steel should be nice and evenly hardened. Post a photo when you can. I like those old Osborn tools.
Edited by MarshalWill
That looks like rust damage combined with physical abuse to me.  Your most important tool will be patience.  I used to have an old Barlow knife with similar damage.  I got it sharpened to the point that I could use it, somewhat, but I could never get out all the edge damage.  It would be tempting to use a grinder to get to a new edge profile, but that could easily overheat the steel unless you know how to keep it cool.  Some file work might be in store before you break out the stones.
I wish you luck!  It could prove to be a worthwhile project.  At the very least, an interesting wall hanger.
It’s the rust damage and evident abuse that gives me some pause. Those nicks look fairly deep. If I can get the edge smooth again, great; I can deal with rust pitting, as long as it doesn’t cause me too many issues with things like skiving. I’m just wanting to make sure I’m not signing up for more frustration than is truly necessary.
