9 minutes ago, MarshalWill said:
I suspected that. Thanks. It's a good looking piece.
Thank you. And the best thing is, I got the 2 sides for a song at Tandy, about $18 each, on sale! I was shocked but snapped them up. I was also not too afraid to put a knife to them to make this. When the leather is expensive, I get stressed.
24 minutes ago, DieselTech said:
For a year in you are doing great.
@DieselTech It would not have been possible without the extensive guidance from all the people here; so many of them that I dare not start naming them because if I miss anyone that would be hurtful.  Really wonderful people!
15 minutes ago, Mablung said:
+1 to such a thread. Phrased appropriately, it will explain why you do what you do and how you learned to do it that way, and invite others with more years and (presumably) more skill to contribute. We all stand a chance to learn something that way.
@Mablung, already started thinking about it. "Phrased appropriately" is absolutely correct. Besides, 'presumably'? That is kind of you. Most of the people surely have much more expertise and skill than I do.
Learning is a life-long journey.
  • Replies 27
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Yeah I always take advantage of tandys clearance sales.
Lmao I bought a full Crocodile hide & I'm almost afraid to cut into it. Not from tandy thou.
I love this site for all the great people willing to help & teach the trade to a new guy like me.
Yeah a lot of great leather workers/crafters here. Or artists in my eyes.
@SUP I do have a question about your round handle construction. Did you use a rein rounder to achieve your round handles? Or did you just use some type of round stock like rope or something like it & then wrapped it in leather & sew?
Thanks.
Edited by DieselTech
I used a rope and sewed the leather around it - a synthetic one so that it would not rot. I looked up rein rounder and I have no idea how to use it!
Incidentally, I ordered the double sided tape from Rocky Mountain Leather Supply.
Envy you your croc hide!  It is usually so expensive I just skip them. I am still very far from reaching a level of using such expensive leather.:huh:
Edited by SUP
4 hours ago, SUP said:
Just completed yesterday. Pattern from Dieselpunk.ro, with modifications.
Made this to learn how to make rounded handles, split gusset with double compartments and to learn more about zippers.
Learnt that when I glue on zippers they turn out straight; use double sided tape and they unstick and pucker, at least for me.
Good job!
If I can suggest a slight change. It looks like that centre line on the gusset is just a design feature. I think they always look better sewn inside out before the gusset is attached, it also gives the opportunity to insert a centre divider should you so wish.
Thanks. I look forward to seeing more of your work. You constructed your handles as I would of. Lol Idk how to use a rein rounder either, but watched a few vids on the process.
@DieselTech I keep feeling that there is so much to learn and just one life to do so!
@toxo it is, in fact, divided into 2 compartments with that division on the gusset.  It is not just a design feature. Internally, there is a central zippered compartment with two open compartments on either side. It is a very nice pattern by Dieselpunk.ro.
If I make this again, I think I will make the central division inside out like you describe.
Absolutely love your color choice, and you did a wonderful job ! I know how much work goes into making a project like that, it's not easy until you make a few, and even then it is challenging. Thanks for sharing it with us.
@rleather thank you for those encouraging words.:)
I've done a few Dieselpunk patterns and sometimes it's well worth making sure there isn't a better way to do something. For example, on the Monte Carlo pattern it calls for the bag bottom to be flush with the bottom with the return being inside the bag so to sew it you had to have one hand inside the bag and the other on the outside and it was a pig to sew and took ages. I worked out that if you inverted the bottom it did two things, firstly it meant you could sew it with both hands on the outside which saved at least an hour of sewing and secondly, it meant the bag sat on a rigid rim with the bottom off the ground. If this is not clear I'll try again.
Yeah I feel I started this hobby too late in life to learn everything I would like to.
You are ahead of me it the bag making department, I have yet to try & make a bag.
I need to buy some books on bag & case making, that shows the different types of gussets & when & where is the place to deploy such gussets.
