Members purplefox66 Posted April 8, 2024 Members Report Posted April 8, 2024 Have any of you used a box style speed reducer. I want to put one on my Pfaff 145 h4 so I can oil the bottom parts of the machine. Quote
Moderator Wizcrafts Posted April 9, 2024 Moderator Report Posted April 9, 2024 15 hours ago, purplefox66 said: Have any of you used a box style speed reducer. I want to put one on my Pfaff 145 h4 so I can oil the bottom parts of the machine. I added a box style reducer to a cylinder arm machine. It has 4:1 reduction. I bought it from Toledo Industrial Sewing Machines. It required two new type 3L v-belts. I recommend locating it in a manner that lets you tilt the machine back to oil it. It can be tricky getting the right position while still clearing the oil pan and wiring. Also, adjusting the belt tension is a bit tricky. Once done, it is usually good for the life of the two belts. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members purplefox66 Posted April 12, 2024 Author Members Report Posted April 12, 2024 Thanks Wiz I appreciate your help. Quote
