Members Stratton Posted May 2, 2024 Members Report Posted May 2, 2024 Buying my first one, so any help and guidance would be much appreciated. Thanks! Quote
Members Mablung Posted May 2, 2024 Members Report Posted May 2, 2024 There was a recent post (or maybe I just read it recently) about the Weaver burnisher machine and how people had modified it. I'll see if I can find the thread. In the meantime, if you dig through the archives or search Google for something like "site:leatherworker.net burnish machine," you'll find some good information already out there. Others may have some more up-to-date suggestions, too, though. Quote
Members stampingdelight Posted May 2, 2024 Members Report Posted May 2, 2024 if used & you are pickin up turn on and try out to make sure works Quote
Members Stratton Posted May 2, 2024 Author Members Report Posted May 2, 2024 Good idea, thanks! Quote
Members DieselTech Posted May 3, 2024 Members Report Posted May 3, 2024 Look into the Cobra burnishing machine. Quote
Moderator bruce johnson Posted May 3, 2024 Moderator Report Posted May 3, 2024 Another vote for the Cobra if you can swing it. I used a drill press and wooden burnishers for years. Burned up two drill presses and went through several burnishers. I got my money's worth out of them for sure with the amount of production pushed through them. Last year my wife bought a Cobra burnisher at Prescott. My nephew used to come down when he had enough work stacked up and use the Ferdco to sew on and then burnish on her Cobra. This year he had us haul home a Class 4 Cobra machine and burnisher from Prescott for him. My wife and nephew don't seem to be violent people but I expect somebody would be bleeding if they tried to take away those burnishers from either one. I had a Weaver through here a few years ago. As much as I like those folks from Mt Hope, that burnisher was not my favorite. It takes up bench space and not the handiest to get around. Fixed speed of 1725 RPM The Cobra is on a pedestal stand and variable speed (2000-3450 RPM). Smaller footprint and about $400 less expensive. Quote Bruce Johnson Malachi 4:2 "the windshield's bigger than the mirror, somewhere west of Laramie" - Dave Stamey Vintage Refurbished And Selected New Leather Tools For Sale - www.brucejohnsonleather.com
Members TomE Posted May 3, 2024 Members Report Posted May 3, 2024 (edited) Another satisfied customer with a Cobra burnisher. I frequently use the sanding drum to level up edges and the wooden burnisher has a variety of shapes that fit my projects. Edited May 3, 2024 by TomE Quote
Members Stratton Posted May 3, 2024 Author Members Report Posted May 3, 2024 Thanks for the recommendations. I'm going with the Cobra! Quote
kgg Posted May 3, 2024 Report Posted May 3, 2024 26 minutes ago, Stratton said: Thanks for the recommendations. I'm going with the Cobra! Why not build your own and save a further couple hundred dollars??? Example: Bench Grinder $139 at https://www.harborfreight.com/power-tools/grinders/bench-grinders/8-in-variable-speed-bench-grinder-with-led-work-light-59300.html Stand: $49 at https://www.harborfreight.com/universal-bench-grinder-stand-59196.html or $59 for a pedestal at https://www.harborfreight.com/bench-grinder-pedestal-68321.html Sanding wheel and burnisher can also be purchased just depends on the diameter of the shaft of the bench grinder. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
