Members Sprocket Posted May 31, 2024 Members Report Posted May 31, 2024 (edited) Hi All, I was able to score these round punches for a low price - I try not to buy obvious junk and these look like they could be rescued. I thought about using my bench top 1x30 belt sander to polish them back to life but before I went and created paper weights, I thought I'd ask here... Can someone point me to a "how to" for sharpening these? Or possibly someone that can refurb them into working order again? Thanks for the help and inspiration I find here. helps if I include the photo... Edited May 31, 2024 by Northmount add pic Quote
Members TomE Posted May 31, 2024 Members Report Posted May 31, 2024 @bruce johnson is an expert who can advise you on value and how to refurbish. Quote
Moderator bruce johnson Posted May 31, 2024 Moderator Report Posted May 31, 2024 Unless your 1x30 is variable speed there is a good chance it won’t be easy to do them on it. I sharpen these type punches on a variable speed belt grinder on really low speed in a slack belt section. Hit the edge already rotating the punch and never let it sit. I work the burr off the inside with a tapered diamond file. Go through the grits and then polish with a few compounds to remove grit lines and get to my final edge. Quote
Members Sprocket Posted June 2, 2024 Author Members Report Posted June 2, 2024 Thanks Bruce - is there a service/vendor where I could send them out? Otherwise they will get put in the "Trust your gut" box of mistake purchases. Quote
Moderator bruce johnson Posted June 3, 2024 Moderator Report Posted June 3, 2024 On 6/2/2024 at 1:30 PM, Sprocket said: Thanks Bruce - is there a service/vendor where I could send them out? Otherwise they will get put in the "Trust your gut" box of mistake purchases. Expand At this point until I retire (1 years and 13 days) I sharpen anything bought from me for the cost of return shipping but don't take in much outside sharpening. That said, if you just can't find anyone close then let me know and you can send them to me to sharpen up for you. Quote
Members Double Daddy Posted June 3, 2024 Members Report Posted June 3, 2024 On 5/31/2024 at 10:03 PM, bruce johnson said: Unless your 1x30 is variable speed there is a good chance it won’t be easy to do them on it. I sharpen these type punches on a variable speed belt grinder on really low speed in a slack belt section. Hit the edge already rotating the punch and never let it sit. I work the burr off the inside with a tapered diamond file. Go through the grits and then polish with a few compounds to remove grit lines and get to my final edge. Expand This is great wisdom, Mr. Bruce...thanks for sharing! I've been wondering about the best way to sharpen these kind of "handled" punches. My round punches are usually chucked into a drill press and get strips of wet/dry sand paper and/or emory cloth (working thru the grits as you suggested) to keep them fine tuned...but...the slack area on the belt sander would be great for what you are describing. Again...appreciate it! Quote
Members Sprocket Posted June 3, 2024 Author Members Report Posted June 3, 2024 Thank you again Bruce - I'll PM if I get stuck. In the meantime... I was thinking of adding a pedal control like a sewing machine - or some other rheostat controller to control speeds on the belt sander. - I wonder if a dimmer switch would work? Once I get the speeds managed - do you hold the part horizontal or vertical to the belt? I can see creating a "grain" by holding the part vertical - in line with belt travel vs horizontal/perpendicular to belt travel. Can you expand on keeping the part rotating? I get the concept but do you use a jig, etc. to keep the part moving? Or is it more of a feel with just your hands? After that, it's just going through the grits to get a polished face? What about squaring up the mouth? If you look close you can see the irregularities there. Am I overthinking this? I do that - often... Quote
Northmount Posted June 3, 2024 Report Posted June 3, 2024 On 6/3/2024 at 1:51 PM, Sprocket said: Once I get the speeds managed - do you hold the part horizontal or vertical to the belt? I can see creating a "grain" by holding the part vertical - in line with belt travel vs horizontal/perpendicular to belt travel. Expand Obviously you want to maintain the cutting edge angle and only take material off the outside, never the inside. So not vertical nor horizontal! Quote
Members dikman Posted June 3, 2024 Members Report Posted June 3, 2024 On 6/3/2024 at 1:51 PM, Sprocket said: I was thinking of adding a pedal control like a sewing machine - or some other rheostat controller to control speeds on the belt sander. - I wonder if a dimmer switch would work? Expand If you have an ac motor belt sander (most likely) then no, a dimmer switch or rheostat will not work. There is no easy way to control such a motor. Variable speed grinders/belt sanders generally use a 3-phase motor with a Variable Frequency Device (VFD) used to control the speed. These can be run off the single phase household supply. Quote
Members oltoot Posted June 4, 2024 Members Report Posted June 4, 2024 be careful as too aggressive heats up the ends and you loose temper. Try taking sheets of sandpaper of varying grits on your marble slab and finish off with a gentle hand and a rolling motion. Quote
Members Sprocket Posted June 4, 2024 Author Members Report Posted June 4, 2024 On 6/3/2024 at 10:48 PM, dikman said: If you have an ac motor belt sander (most likely) then no, a dimmer switch or rheostat will not work. There is no easy way to control such a motor. Variable speed grinders/belt sanders generally use a 3-phase motor with a Variable Frequency Device (VFD) used to control the speed. These can be run off the single phase household supply. Expand To clarify: My machine is 120V 1phase 60hz, 1200W - a bench top 1x30 sander from Harbor Freight - not an expensive unit (approx. $40). Closer to a vintage sewing machine than not. A rheostat controller can throttle the current flow and moderate the motor speed much like a vintage sewing machine - for about $30 shipped. No lighting dimmer switches need apply - not rated for the job - but a motor controller appropriately rated. Compared to an industrial machine at 3phase of any voltage utilizing an electronic VFD - a completely separate piece of equipment there. That's more of a professional knife maker or metal fabrication shop item. Northmount - following the cone, yes - not true horz/vert but a general orientation of the part to the belt. Oltoot - Thank you for reminding me about temper and heat. The experiment continues... Thank you All for your input. appreciated. Quote
Moderator bruce johnson Posted June 4, 2024 Moderator Report Posted June 4, 2024 On 6/3/2024 at 1:51 PM, Sprocket said: Thank you again Bruce - I'll PM if I get stuck. In the meantime... I was thinking of adding a pedal control like a sewing machine - or some other rheostat controller to control speeds on the belt sander. - I wonder if a dimmer switch would work? Once I get the speeds managed - do you hold the part horizontal or vertical to the belt? I can see creating a "grain" by holding the part vertical - in line with belt travel vs horizontal/perpendicular to belt travel. Can you expand on keeping the part rotating? I get the concept but do you use a jig, etc. to keep the part moving? Or is it more of a feel with just your hands? After that, it's just going through the grits to get a polished face? What about squaring up the mouth? If you look close you can see the irregularities there. Am I overthinking this? I do that - often... Expand First off if the edges are irregular you need to square that up. Open side down on abrasive paper until you get a flat edge all the way around. Then when you hit the edge to the belt you need to already be rotating the punch in your hand. Same for removing it from contact with the belt. My angle is slightly higher than the coning of the punch to make a slight secondary bevel. Anytime you leave the punch sitting against the belt without rotating it you can create a flat spot at worst and thin spot at almost worst. Watch how the edge develops. Magnification is your friend to see closeup and get an even edge thickness. (Optiviser with a #5 plate is my usual choice for punches, #10 for finer work) As the flat edge gets thinner and thinner you should be going to finer and finer grits to refine the edge and remove grit marks from the outside edge. The final abrasive should complete the bevel and make a fine burr on the inside of the edge. I use a diamond file to remove that burr. I polish on a sisal wheel with black and then green compound, sometimes go on to purple. Wipe the burr off the inside again and polish some more until the burr fragments are gone. Quote
Members Sprocket Posted June 5, 2024 Author Members Report Posted June 5, 2024 Thank you Bruce - this should be enough for me to be dangerous. The $$ I'll spend on belts and supplies will probably afford me at least one new punch but hopefully I'll develop a new skill - or at least rule it out. Quote
Members dikman Posted June 5, 2024 Members Report Posted June 5, 2024 On 6/4/2024 at 5:03 PM, Sprocket said: To clarify: My machine is 120V 1phase 60hz, 1200W - a bench top 1x30 sander from Harbor Freight - not an expensive unit (approx. $40). Closer to a vintage sewing machine than not. A rheostat controller can throttle the current flow and moderate the motor speed much like a vintage sewing machine - for about $30 shipped. No lighting dimmer switches need apply - not rated for the job - but a motor controller appropriately rated. Expand Have a close look at the motor, if it uses brushes then yes, a simple speed controller should work (although I would suggest an electronic controller rather than a simple rheostat), if the motor doesn't have brushes then it is an induction motor and the controller WILL NOT work. Vintage sewing machines used brush-type motors to allow for rudimentary speed control. Quote
Members Sprocket Posted June 6, 2024 Author Members Report Posted June 6, 2024 On 6/5/2024 at 10:41 PM, dikman said: Have a close look at the motor, if it uses brushes then yes, a simple speed controller should work (although I would suggest an electronic controller rather than a simple rheostat), if the motor doesn't have brushes then it is an induction motor and the controller WILL NOT work. Vintage sewing machines used brush-type motors to allow for rudimentary speed control. Expand Thank you for that info - if it's a brushless motor, would there be a module or other indicator? I'm not exactly sure I'll be able to get into the motor that far - I may have to do some disassembly of the machine to verify. I'll certainly look at an electronic controller. Quote
Members dikman Posted June 6, 2024 Members Report Posted June 6, 2024 If it uses brushes then there should hopefully be some sort of screw fitting where the brushes are mounted, there will be two on opposite sides of the motor housing. Quote
Members Chef niloc Posted July 29, 2024 Members Report Posted July 29, 2024 Another way if you don’t have the power tools is the “mousepad sandpaper sharpening technique” there’s tons of articles on it if you Google it but basically it’s just what it sounds like.Aautomotive wet/ dry sandpaper ( 500, 800, 1000 grit is what I use) on top of a somewhat forgiving service. Rubber cutting mat or a newspaper/ magazine I’ve heard works. I find it best to spray It was glass cleaner ( the aerosol one) as opposed to just water.. Quote
