Members JackPeter Posted July 12, 2024 Members Report Posted July 12, 2024 Hi everyone, I’m using Angelus 4-Coat with an airbrush (Craftool All-in-One airbrush) and I just can’t seem to get anything consistent. I think what’s happening is the 4-Coat is getting tacky in the nozzle. I did read I could use 2-Thin but I’m still getting the same type of consistency. Perhaps I’m adding too much of the coat? Quote
Members JackPeter Posted July 18, 2024 Author Members Report Posted July 18, 2024 On 7/16/2024 at 10:46 PM, Doc Reaper said: Is it like milk??? Sort of! It’s turns almost into glue. Perhaps it’s too much of the top coat and not enough thinner Quote
Members dikman Posted July 18, 2024 Members Report Posted July 18, 2024 Glue? It should be the consistency of milk, like doc said, and runny. Are you sure the thinner is the right type for the paint? A quick search shows others having the same problem. It's a urethane finish so will likely need thinning quite a bit but the wrong thinner will certainly turn it "gluggy". Maybe try lacquer thinners? Funnily enough some have said they can spray it straight from the bottle. Perhaps the needle in the airbrush is too fine? Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
CFM chuck123wapati Posted July 19, 2024 CFM Report Posted July 19, 2024 i would look closely at the air brush also, can you set the air pressure on that thing or can you even tell if it has pressure? Your paint should be the viscosity of milk like the others say. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Contributing Member Samalan Posted July 19, 2024 Contributing Member Report Posted July 19, 2024 when you put a stick in the paint pull it out when you have no droplets when it runs off the stick it is good. plus the right thinner. Quote
