I have recently acquired this wonderful machine, and am looking for some more bobbins for it. Does anyone have any ideas where I can get any? I currently have two. Thank you.
I´m not 100% sure but could be that Singer 45K bobbins fit - I´d compare the measures.
https://www.ebay.de/itm/143603147753
They look similar, the one I have seems slightly smaller but it might be worth giving it a go, thank you!
BTW your bobbin winder looks as if it is incomplete and from a different machine. Maybe worth checking the 45K bobbin winders too ;)
https://www.ebay.de/itm/156265077932?
It's quite possible, cheers!
Contact Toledo sewing machines . . . they are one of our sponsors up there at the top . . . Bob is very knowledgeable . . . I get my cowboy bobbins from him and my Tippmann bobbins from Tipmann.  The tipmann bobbins are smaller . . . but in a pinch, I can use them.  His number is 866-362-7397
Give Bob the dimensions . . . I'd bet he'll have an answer for you.
May God bless,
Dwight
Edited by Northmount
changed thimbles to bobbins
www.dwightsgunleather.com
Brilliant, thank you, I'll have a look.
Beautiful old machine, fairly rare even in the UK and like an honest politician elsewhere. There's a few threads scattered around discussing them on this forum.
The bobbin does look about the right shape for a 45K but without anything to scale it off it's hard to tell. My 45K bobbins are 31mm long and 20mm diameter. If your Pilot bobbins are very close to that I would buy a few cheap ones to try gently in the Pilot.
Hartley Sewing in Walsall is one of few dealers likely to have much/any knowledge on these things or parts lying around.
  • 1 month later...
Hi Matt, thank you for your reply, the 45K bobbins seem cheap enough so I might give them a go. I hate running out halfway through a belt!
BUSM (not BUSMC) Pilot. It took a little rabbit trailing to figure out what this one was. British United Shoe Machinery.
Interesting old machine but I'm unlikely to ever run across one in America.
- Voltaire
- Aristotle
