Members Sundancekid2 Posted September 3, 2024 Members Report Posted September 3, 2024 I have an Adler 105-64. I need the top v belt and can't fine what size it needs. I think I measured correct, 1/4 x 63". Hope someone can help and give me sizes and brand. Thanks Quote
CowboyBob Posted September 3, 2024 Report Posted September 3, 2024 10 hours ago, Sundancekid2 said: I have an Adler 105-64. I need the top v belt and can't fine what size it needs. I think I measured correct, 1/4 x 63". Hope someone can help and give me sizes and brand. Thanks You can buy belts @ a hardware store,auto parts,lawnmower,etc get it 3/8" wide by the length you measured. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members Sundancekid2 Posted September 3, 2024 Author Members Report Posted September 3, 2024 I am not sure if the 3/8" wide belt fits the pulley on sewing machine, the pulley opening appears to measure 1/4" approximately. The handwheel pulley down to the axel pulley is 63". Both measure close to 1/4" wide. Quote
Moderator Wizcrafts Posted September 3, 2024 Moderator Report Posted September 3, 2024 Just now, Sundancekid2 said: I am not sure if the 3/8" wide belt fits the pulley on sewing machine, the pulley opening appears to measure 1/4" approximately. The handwheel pulley down to the axel pulley is 63". Both measure close to 1/4" wide. You can buy 1/4 inch diameter leather belting and a steel C clip and cut it to size. Order a 64 inch length and you should be golden. You'll need a tiny hole punch, like for poking a hole for a hand stitching needle. Most revolving punches have this size in them. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members shoepatcher Posted September 3, 2024 Members Report Posted September 3, 2024 105-64 should use a 3L v belt. Send pic of pulley. glenn Quote
Members Sundancekid2 Posted September 3, 2024 Author Members Report Posted September 3, 2024 Will do, when I get to the shop! Thanks Quote
Members Sundancekid2 Posted September 3, 2024 Author Members Report Posted September 3, 2024 It will not allow me to post. Says the file is to big. Sorry. Quote
Northmount Posted September 4, 2024 Report Posted September 4, 2024 18 hours ago, Sundancekid2 said: It will not allow me to post. Says the file is to big. Sorry. If your files are too large to post here due to file size restrictions, you need to resize your files to fit. Follow this link for some helps and suggestions. https://leatherworker.net/forum/topic/15122-how-to-post-pictures-on-lw/?do=findComment&comment=551171 There are lots of Apps, software, and online tools available on the web, or even built into your device to enable you to reduce your file sizes. 800 pixels in the longest dimension is quite adequate. Smart phone screens and many monitors don't display high res files in high resolution. People that live on the fringes of the internet appreciate smaller file sizes and high res photos may take from 10 minutes to hours to download. Quote
Members Sundancekid2 Posted September 5, 2024 Author Members Report Posted September 5, 2024 Thanks! Quote
