I can't remember: is it light dye first, then dark, or dark first, then light?
Also, while I'm here, where in the process should I apply antique?
Don Gonzales has a good video of applying antique finish.
I always do my lighter dye 1st,  then I apply the antique gel. Then after antique gel drys I seal it with a sealer.
You should always start with the lighter shade of dye first - remember you can always make it darker but not the other way around
Edited by SamB
Typo
I apply antique after all my dye & oil work is done and a resist has been applied. Then antique and top coat or seal.
:17:
HS
I have been able to draw the dye back out with acetone (accidental discovery). I doubt that it would pull all of the dye out without staining, but it may be worth experimenting on some scrap. I got kind of a cool ombré effect, but I need to develop my basic techniques before such experimentation.
Moved to Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
By the way, you should study this area.
