Guys & gals I would like to buy a strap cutting machine.
Just curious if any of you have seen or used the TandyPro manual strap cutter.
I'm curious if I can get by with it for a few years.
Or is it junk?
Is there a better china/import brand option out there?
Thanks. Any & all help will be greatly appreciated.
Well I just said "F" it & bought 1 of these strap cutters. I will let you know what I think of it in a few days if I get around to it.
Lmao I got a Cobra 26 to assemble too.
I'll be interested to hear your experience...I'm unlikely to buy one any time soon, but am curious how well it works.  I did initially look for cheaper Chinese options, but didn't see anything comparable - they were all far more manual.
As soon as I get around to installing the cutters blades. I will report back with my thoughts. I did watch this guy cut saddle skirting with it & I know it wasn't designed for that. But it did cut the 14-16oz leather saddle skirting.
  • 2 weeks later...
Sorry I didn't have the opportunity to respond to the first post but likely it's a good machine.  I bought a strap cutter from Weaver's years back and resembles yours a lot.  I'm more than happy with it.  Takes some getting used to if you want to split directly from a side. Best bet is to hand cut a wee bit more than you need from the side and then run it through.  A little waste but you've no "wonky" straps!
Edited by THein
www.singletreeleather.com
Thanks. Yeah I was going to hand cut a 10-12" wide strip out of the side of leather.
Then run it thru the strap cutter for whatever given width I need.
I would just check that the gears are not plastic ones as I have seen some models have them and do not last long cutting thicker than recommended.
YouTube Channel
Instagram
This video I did a little while ago could help you on this - https://youtu.be/Q3cVOtCNjEg?si=xrCJA5Rep8YEl89Y
Edited by RockyAussie
YouTube Channel
Instagram
Thanks. I appreciate it. I watched that video here recently. Then went to a metal fab shop & purchased a 8ft section of 1½" stainless steel flat strap.
Ok guys & gals, I finally got around to testing the TandyPro manual rotary strap cutter.
It is definitely a keeper. This cutter is nice. If you set it up, according to the manual.
Here is some 10-12oz Hermann oak latigo. Cut it like butter. Awesome!!!
Decided to really test the machine out. This is 14-16oz Hermann oak saddle skirting. Cut it like butter! Awesome machine for the money.
Looks like it does a nice job. All you need to do now is change the hand crank to a pulley and strap a servo motor on.
kgg
kgg
I have thought about doing that. A speed reducer & a 750watt brushless servo motor.
My only real gripe is, I think they should have included more material fingers that holds & separates the leather from the rollers/cutters.
Maybe consider get some extras or having a couple 3D printed.
kgg
I'm following this conversation. Definitely interested.
Posted IMHO, by Wiz
Only thing that would be hard to source is a v-belt pulley with a square drive. That is if a did decide to try & motorized it.
That part of the setup is a bit silly really. If the fingers were made out of something heavier (3mm or 1/8") and with a longer back section they would not need to be spaced and locked in place. The weigh at the back would let the front part ride against the cutter shaft. I have an old machine like that and to change position I just lift the finger forward and move it sideways to where I want it. 5 seconds to change each finger.
YouTube Channel
Instagram
Yes that is the only big gripe with this machine. The stupid finger set up they used. It's a PITA. But I'm happy with it.
It sure beats cutting straps by hand & a knife.
I already got plans to modify/fabricate a new finger setup. Using heavier material for the fingers & either lock collars or round turn buckle clamps.
  • 1 month later...
Update: The more I use this strap cutter, the more I like it. It does a real nice job!
Here is some 5oz pebbled veg-tan that I cut, 3-1½" wide straps & 1-1" wide strap. Cut it like butter.
Did you happen to notice if the gears are metal or plastic?
The gears are made of metal, & it's got sealed roller bearings on all the shafts.  It seems to be a decent machine for the money. I'm pretty happy with it.
Thanks for the good info!
