Members Brokenolmarine Posted October 5, 2024 Author Members Report Posted October 5, 2024 Okay y'all, fill your coffee mug, this will be a long stretch. I was busy today. So, the oil dried overnight and my first task today was to wax the boards and get them ready to glue up. I have talked in a lot of my posts about the beeswax. In this series I have shared pics of the actual products. This is the Beeswax I use. I have to say I LOVE the smell of this stuff. NOT like we used to smell the freshly mimeographed tests they handed out when us old folks were in school smell, or that dizzying smell of two part epoxy in a closed room smell. This stuff smells GOOD. It's bring back fond memories good. When I apply the wax, I have learned a few tricks over the years. I have a cheap hair dryer and I heat whatever project I am going to wax a little. I do mean a little, you don't want to overheat whatever it is and damage it, or change it's configuration. I avoid this by holding the project in my hand. Just before I apply the wax I aim the hair dryer into the can for five to ten seconds. This softens the wax, I watch and you can see a slight color change. I don't want it runny. By heating the wood, bone, etc, you also let the wax get down into the pores to better protect. I apply a coat and buff it out, then apply a second coat and buff. We are waxed here, that soft sheen. For high gloss you build up several coats and buff. You'll get there. I like the soft glow. Quote
Members Brokenolmarine Posted October 5, 2024 Author Members Report Posted October 5, 2024 At this point I was ready to glue up, so I pulled the painter's tape from the protected areas and set up. I matched the reference markings and applied glue with the acid brush, and matched and band clamped. Bar clamps insured the middle of the long sides were tight against the bottom panel. Quote
Members Brokenolmarine Posted October 5, 2024 Author Members Report Posted October 5, 2024 Next, while the glue was setting up, I pulled out the 1/4" plug cutter and cut a dozen plugs in a block of scrap from the original board the case was cut from. After using a mini-square to mark the locations of the holes I wanted, I used a Forstner bit to countersink eight holes for reinforcement of the glue up. Then used an appropriate drill bit to predrill holes in the countersink for eight finishing nails. Quote
Members Brokenolmarine Posted October 5, 2024 Author Members Report Posted October 5, 2024 Many would use a hammer to set the nails, but I used a punch and my brass mallet and a series of light taps to seat the nails. Much more control. I have ruined a piece in the past missing with a hammer. Difficult to remove a ding from a good sized hammer. So I dip each nail in the wood glue, set it in the hole by hand, then drive it with the punch and mallet. Once the nails are set, I pull a plug from the block and using a nail, run glue around the inside of the countersink. Then set a plug with a light tap of the rawhide mallet. Quote
Members Brokenolmarine Posted October 5, 2024 Author Members Report Posted October 5, 2024 While the glue sets on the plugs, I play with my New Maker's Mark, to create a new one for the panel. I'll glue it over the one carved in the panel with contact cement. Three or four tries and I've got a good one. Quote
Members Brokenolmarine Posted October 5, 2024 Author Members Report Posted October 5, 2024 With the glue set, it's time to trim the plugs off flush. You need the right chisel and it has to be sharp. Keeping them organized and sharp is easy if they are properly stored. I took care of this one winter when I had nothing to do. I chose a wide flat chisel and my heavy mallet. The key to a clean cut is keeping the chisel flat against the surface, cutting with the grain, and a smooth even cut. If you hit too hard you'll break the plug and pull a chunk out of the countersink. I know this from experience. You get set up, tight against the plug and then a firm even stroke. Quote
Members Brokenolmarine Posted October 5, 2024 Author Members Report Posted October 5, 2024 Eight set ups, eight cutting strokes, eight flush cuts. I got lucky. Touch them with Watco Oil and they come very close to matching now. After they dry and are waxed, they may match perfectly. If they don't, I'll just say I planned it that way, as an ACCENT. Yeah, That's the Ticket, an accent. Yeah.... Far from perfect, but there is still a lot to do. I'll address the corners when I finish the lid, I'll sand them all together, and close that gap. Start on that tomorrow. Quote
Members Brokenolmarine Posted October 5, 2024 Author Members Report Posted October 5, 2024 I cemented the new logo to the panel and installed the panel into the case using the quarter round molding to hold it in place. I pinned the molding down using a brad nailer, but did NOT glue the molding to the leather or the case sides, JUST in CASE. That was looking good, so it was time to install the magnets. I laid them out on the lines on the leather and insured they were aligned with one another using a pair of three foot rules. With the provided screws, I drilled pilot holes and carefully installed the magnets. I had placed the case on a pair of 2x2s as I knew there was a slight chance the screws might go thru the bottom of the case, so I wanted to be prepared. Slow and steady, verifying each position before I drilled, I got them installed. It looked good. Three screws did penetrate the bottom of the case by about 1/16th of an inch. The Dremel with a cutoff wheel made quick work of the little bit that showed thru. No worries. The new logo came out very nice as well. I'm going to love this new stamp on my leather work. Next on the to do list is starting on the lid and plexi window. Then installing lighting and hinges. Stay tuned. Quote
Members blue duck Posted October 7, 2024 Members Report Posted October 7, 2024 This is a great post. Look forward to the finale. Quote
Members DieselTech Posted October 7, 2024 Members Report Posted October 7, 2024 Looks awesome. Beautiful work. 100years from now somebody will really appreciate & admire the work that was put into this case. Quote
Members Brokenolmarine Posted October 8, 2024 Author Members Report Posted October 8, 2024 Over the last few days I have made some decent progress. I started on the case top. I was going to use the smaller of the two boards I prepped, but I was NOT happy with the look, and the fit was TOO close and might have been way too short after trimming. I went back into the woodpile and found some black cherry I liked and went thru the process. I ripped two long pieces the right width, then cut the four pieces needed to make the frame and test fitted them together. The test fit was successful, and I needed to sand away the burn marks caused by the table saw. This was caused by the density of the wood and the length of the cut. Note that the dados on these are not as wide and are very shallow. Rather than setting up the stacked dado blade, I cut these in two passes over the table saw blade. The sanding of the top frame was accomplished on the new 1x30 belt sander with the platten. Quote
Members Brokenolmarine Posted October 8, 2024 Author Members Report Posted October 8, 2024 Got the case top glued up and pinned, and let the glue cured using all the same processes as the previous ones used on the case. Cut the plugs using the 1/4" plug cutting from the special tools drawer. This time I cut plugs from the leftover scraps of Black Cherry... and I cut a bunch even though I only needed four. I planned to snap them loose rather than setting up the bandsaw to cut the bottom off the scrap, so there was a chance some wouldn't break clean at the bottom.... extras are nice to have. Got them all plugged and left them to cure. Quote
Members Brokenolmarine Posted October 8, 2024 Author Members Report Posted October 8, 2024 After trimming the plugs flush with the mallet and chisel, I test fitted the top frame to the case. It's looking good. I won't apply any finish until the top's edges have been shaped and I have prepped everything for final assembly. Next step is to cut the plexi. A REAL pucker factor moment. Crack that panel and it's $50 to replace the panel... We are getting close, but I have been slowed down a bit. CUT the tip of my right index finger last night cleaning a broiling pan, cut it deep. I know now why torturers start on the fingertips. Quote
Members Brokenolmarine Posted October 8, 2024 Author Members Report Posted October 8, 2024 Went to Home Depot this morning and picked up a couple things. I picked up four more hanging loops, this thing is getting heavy. I also picked up a package of special blades for the jigsaw, made especially for cutting plexiglass, after watching a couple videos on "How best to cut Plexiglass without breaking it." Who Knew they had special blades? The teeth on the blades are smaller, closer together, and angle BOTH ways, opening a channel rather than melting back together behind the cut, leaving a smooth clean cut. NOT cheap, but after cutting this panel, worth every penny. It fits, and the cuts didn't need to be sanded or cleaned up in any way. For now, I have left the protective sheeting on the panel. It will come off later, when everything is done and I'm ready to fully assembly the case. Still have to drill some Tiny Holes to mount the plexi, mount the hinges and latches, mount the lights and the hangers. Almost done here. Done, for the day. Quote
AlZilla Posted October 8, 2024 Report Posted October 8, 2024 Got it. I was picturing this thing laying flat on a table. Now I see where you're going. Also - special blades for plexi ... ?! Cool. I might revisit making plexiglass patterns. Quote
Members Brokenolmarine Posted October 9, 2024 Author Members Report Posted October 9, 2024 It's going to hang over the table by the front door in the entry, and will be lighted to show off the knives. Vertical display, that's the reason for the long magnetic double bars. I'll try and get a pic of the location in the morning. We are getting close to the end now. I need to shape the edges of the top, and stain it, then add the LONG piano hinge and the latch to hold the door closed. This will have SIX hangers. SIX. That should hold 'er. Quote
Members Thadrick Posted October 9, 2024 Members Report Posted October 9, 2024 I use a flush cut bit in my router with a strait piece of wood as a guide for cutting plex. I also use it for cutting thin aluminum panels very successfully Quote
Members Brokenolmarine Posted October 9, 2024 Author Members Report Posted October 9, 2024 As promised, here is the pic of the address where the case will live. The painting and the lamp will go away, and the medal / flag display will likely be moved to another location. I made that from a chunk of firewood we were splitting from a tree we cut down. The boxes on the table will stay, they contain the sheaths for most of the knives. I'm thinking seriously of hanging my Marine NCO Sword above the display case, and maybe my Calvary Sabre Replica below it. Quote
Members dikman Posted October 9, 2024 Members Report Posted October 9, 2024 Hanging the swords next to the case is a good idea as being edged blades they fit the theme. How about crossed swords above the case? just a thought. Quote
Members Brokenolmarine Posted October 10, 2024 Author Members Report Posted October 10, 2024 I was thinking the sword and the scabbard crossed above the display case... Then a gift from a friend in return for what they considered a huge favor... A high end collectible replica of the Braveheart sword hung vertically to the left of the table. The thing is Long... Four or five feet, weighs about ten pounds. Quote
Members DoogMeister Posted October 10, 2024 Members Report Posted October 10, 2024 Ever try a French cleat for hanging something heavy? Love the sword idea. Quote
Members Brokenolmarine Posted October 10, 2024 Author Members Report Posted October 10, 2024 Years ago... But it had slipped my mind. Thirty surgeries. The last five major ones averaged five hours. All that time under messed with my memory. I find I had forgotten a LOT of the small tricks and techniques, and have trouble with short term memory as well. I'll look at that as a viable option. Thank you very much. Quote
Members Brokenolmarine Posted October 12, 2024 Author Members Report Posted October 12, 2024 I wasted two work days sitting in the living room with my cell waiting for a call from the Wheel Chair service folks to schedule a visit for the scissor lift chair I use in the shop when I work at the Drill Press or the Band saw. The batteries won't hold a charge for more than a day. Used to hold the charge for a week or so. The VA called in the service contract and said they would call to schedule. My cell doesn't work in the (metal) workshop. They never called. I was NOT happy. Got out in the shop and got to work on the retention frame for the Plexi. I basically repeated the process I used to make the top for the case, so NO pics, but basically, set up the table saw, ripped two addition seven foot pieces of black cherry. This time however, they were quarter inch rather than three quarter inch. I took them over to the sander and cleaned them up and sanded away any saw burn marks. Then, an additional step, I used a small hand plane to cut a small forty five degree angle on ONE side corner of the strip then back to the sander to round over that corner. That will be the top edge on the glass side. I don't like to use the router if I can avoid it. Hooked up the Miter saw and vacuum and cut the pieces to length. Now we have the retention frame for the glass. Fits great. IN the pic below, it seems to bow slightly, but that's because they are just laying on the case, once I pin them, they will fit exactly. Time to apply some stain to the top. Prior to that, I sanded the corners and removed those small defects in the fit, and sanded the plugs one last time to insure they were perfectly flush. Once we were good, I used Watco Golden Oak Oil to apply that finish, and I am very happy. The contrast should make the Display Case Pop.... We are getting so close now. I can't wait to hang this thing and fill it. Watch this space... Quote
Members Brokenolmarine Posted October 13, 2024 Author Members Report Posted October 13, 2024 We have glass, next up, hinges and lights. Quote
Members Gezzer Posted October 14, 2024 Members Report Posted October 14, 2024 Watching every day Quote
