For whatever reason, I always have horrible luck when skiving projects. The skiver seems to occasionally "catch," resulting in severe gouging. I suspect this may be due to my skiver (a Tandy SuperSkiver.) Would a well-stropped woodworking plane produce a more even skive?
My two cents ...........
I have used a plane for wood most of my working life . It is a wonderful tool but it is more than a sharp blade and with many adjustments it is not real easy to learn . You may have wonderful luck with one but for  me it is not a skiving tool . You'll find the sole in your way for most skiving work .
Good luck !
A belt sander is effective. Bench mount, not hand held.
Maybe just the blade, out of the plane body?
I'm a woodworker and I have many planes tuned, sharp, and ready to go. They don't work great for skiving leather. A low angle block plane set for gossamer shavings works, but not as consistent as a sharp edger used by a skilled person.
Going around corners and curves tends to chew instead of cut.
I encourage you to experiment and prove me wrong.
I had some china edgers and I thought I was doing great leather work, and then I got some tandy shivers and my bevels were much better.
I was at a Harbor Freight store a couple months back . . . saw a small . . . really stout . . . putty knife.
Said to my self . . . wonder if I could make that into a skiver . . . sure would be nice.
I did . . . had to seriously put a long angle on it . . . had to strop it really good . . .
It works for some of the holster work I need it for.   I can also use my round knife for a big job  . . .  this is for grab an go skiving . . .
May God bless,
Dwight
May God bless,
Dwight
Thanks! I'll try this.
Ironically, I was just at Harbor Freight yesterday.
