Members Calidora Posted November 14, 2024 Author Members Report Posted November 14, 2024 Apparently I've reached the limit of attachments I can do for this post. I have other pictures but can't post them. Quote
Northmount Posted November 14, 2024 Report Posted November 14, 2024 4 hours ago, Calidora said: Apparently I've reached the limit of attachments I can do for this post. I have other pictures but can't post them. There is no limit that I am aware of. I have seen posts/threads with many more attachments/photos than you have posted. You should reduce your file sizes further. 800 pixels in the longest dimension is quite adequate. Try again later. There may be something else at play here with the device and or browser or ISP you are using. Quote
Members Calidora Posted November 14, 2024 Author Members Report Posted November 14, 2024 3 hours ago, Northmount said: There is no limit that I am aware of. I have seen posts/threads with many more attachments/photos than you have posted. You should reduce your file sizes further. 800 pixels in the longest dimension is quite adequate. Try again later. There may be something else at play here with the device and or browser or ISP you are using. I guess you are right. I got the option to post more now Quote
Members Calidora Posted November 14, 2024 Author Members Report Posted November 14, 2024 (edited) One of the back Edit: Nope, still can't add attachments. Edited November 14, 2024 by Calidora Couldn't post pics? Quote
Members dikman Posted November 14, 2024 Members Report Posted November 14, 2024 Glad it worked out for you. $300 for a post-bed machine is pretty good, particularly as they don't appear to be very common unlike flat-beds or cylinder arms. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Calidora Posted November 15, 2024 Author Members Report Posted November 15, 2024 On 11/10/2024 at 11:01 AM, Constabulary said: As mentioned before ex factory it is using a needle system with fairly thin shafts and you can probably get it to sew with 138 thread if the needle plate has a large enough hole but you most likely you have to convert the needle bar for using a common needle system like 135x16 and you need a new tension unit. So expect to invest approx $50 or more in it for parts + some tinkering. Maybe new needle plate and feed dog and I´m not sure if the roller foot is ideal for your work. But you can convert that as well.... But it all takes parts, time and tinkering. What do I need to convert the needle bar? Quote
Members Calidora Posted November 16, 2024 Author Members Report Posted November 16, 2024 (edited) Let's try this again Nevermind. If it's ok I'll start another post when I have the machine up and running and add more pictures then. Edited November 16, 2024 by Calidora Still no attachments? Quote
Members Constabulary Posted November 16, 2024 Members Report Posted November 16, 2024 14 hours ago, Calidora said: What do I need to convert the needle bar? basically a new needle bar. Your machine is the 2nd type 51w and needs a 6.35mm needle bar as it was used in the Singer 111w triple feed machines. Like this one: https://www.ebay.com/itm/152426180931 But you have to shorten it. LW member @eddo has done this with his machine too: Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Calidora Posted November 16, 2024 Author Members Report Posted November 16, 2024 8 hours ago, Constabulary said: basically a new needle bar. Your machine is the 2nd type 51w and needs a 6.35mm needle bar as it was used in the Singer 111w triple feed machines. Like this one: https://www.ebay.com/itm/152426180931 But you have to shorten it. LW member @eddo has done this with his machine too: Thank you. I'll do that. Quote
Members Calidora Posted June 23, 2025 Author Members Report Posted June 23, 2025 (edited) I finally got this machine set up. I was wondering. Did I get it threaded properly? Edited June 25, 2025 by Northmount Removed duplicated file Quote
