Members Gridix Posted January 11 Members Report Posted January 11 Hey everyone, I just started my first project to being my leatherworking journey. The wallet I am trying to make is lined, and when i try to fold the shell, these weird creases/wrinkles are forming. Please see the attached photos. Does anyone know why this is happening? The two pieces are glued together. Thank you! Josh Quote
Members DieselTech Posted January 11 Members Report Posted January 11 I think your issue with the wrinkles is this: Instead of gluing in your liner when it is flat, you need to glue your lining in when the outer piece is slightly folded/bent. Quote
Members Dwight Posted January 11 Members Report Posted January 11 The same problem is "not a problem" in most holsters . . . as it is in the front sight area of the holster. But it looks ugly . . . To cure it . . . I fold the lining after wetting it . . . allowing it to dry . . . and stay curved . . . I also fold the outer layer . . . I then position them together before any glue is applied . . . and when I have them in my hand EXACTLY the way I want them . . . I make a ball point pen mark on the edge top and the edge bottom . . . both near the center of the fold. I then apply the glue . . . line up the marks . . . and put them together . . . usually with a board or something between them so I can roll the pieces and make sure they are stuck good. Works well that way . . . no wrinkles. May God bless, Dwight Quote
Members Gridix Posted January 11 Author Members Report Posted January 11 Ok thanks for the advice ! I will try it again with your suggestions and let you know. Josh Quote
Members dikman Posted January 12 Members Report Posted January 12 A common issue for holster makers when making lined holsters, it caused me a bit of consternation the first time it happened to me! It will happen with anything that is lined when you try to make a sharpish fold. The only way to avoid it is to pre-curve the pieces, as Dwight said. It can be a bit fiddly trying to line up two curved pieces that have contact cement on them but I do as he also said and use stiffish plastic to keep the pieces apart, working it out a bit at a time. Quote
