Members Eelco Posted January 26, 2025 Members Report Posted January 26, 2025 Ive been wanting to make my own indoor leather minimal shoe for a while, really optimizing for breathability. Ive noticed that the leather boots I have vary a lot in breathability. Some of that makes sense; thicknesses and leather types; but in part its a bit of a mystery to me. Especially lined leather can be a real disappointment in breathability; even when the total thickness isnt that much. Im inclined to explain this in terms of shoe cement used. If you look at the chemistry of the most popular shoe cements, they are not vapor permeable at all. Infact they often prize themselves on their ability to block water. But that goes both ways. The construction im currently considering is an upper sticheddown to the insole, and then a glue only leather outsole. This being a barefoot indoors design, I want to keep the total sole thickness minimal. And ideally, the outsole should be easily replacable. What im hoping is that the right use of PVAc glue will serve me for these indoor soling purposes. What im hoping is: * the glue I find wont make my sole fall off all the time * if I want to replace the outsole, it should be easy to get off by soaking in warm water / maybe acetone? * the thin leather sole plus water permable glue will noticeably contribute to overall breathability * I can find a PVAc sufficient flexible for this purpose in the first place (adding 15%wt PEG400 should help with that?) Does this sound at all like a reasonable experiment, or should I save myself the time? Im having a hard time finding shoe cements explicitly advertizing themselves as breathable. If it sounds like this is unlikely to work, perhaps a good option would be thin rim of a stronger cement, with the bulk interior of the sole being PVAc? Quote
RockyAussie Posted January 27, 2025 Report Posted January 27, 2025 If it is for indoor use a couple of eyelet holes put into the instep area just above toe sole will allow air to be move in and out as you walk which might be a lot easier option. I do this even on outdoor wear shoes which is only a problem when I step in water. Keeps the shoes from getting smelly as well. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members Eelco Posted January 27, 2025 Author Members Report Posted January 27, 2025 True; or I could make a sandal instead . My interest here is somewhat theoretical though, to figure out how much glue matters to vapor permeability in practice. Quote
Members Eelco Posted January 31, 2025 Author Members Report Posted January 31, 2025 I did some experiments with PVAc; made a small sheet out of pure PVac, 10wt% and 20wt% PEG400. The pure material is not very flexible and can be cracked even at room temperature, as expected. The 10% can be cracked right out of the freezer, the 20% remains flexible in all conditions tested. Both are very tough and ductile and seem like they would make for perfectly nice leather glue (as is the conventional wisdom). Ill guess Ill make a bigger thin sheet on a piece of silicone sheet so I can fold it into a little bag, then put in a damp sponge, plus a paper and PP bag as controls, then weight them in over time to see if it makes any real world difference in water permeability. I got one shoemaker to talk to me about what they use for their boot linings, and its latex. Again not sure what it matters in practice but it might explain why the lined leather boots I have are about as breathable as a latex glove. I also have PVB resin that I think in theory might also work great for leather with some PEG400 added, and its also a highly hygroscopic polymer, capable of absorbing almost 10% water; even before mixing in any PEG. Probably should also add that to my experiments. Havnt been able to find anyone directly commenting on this topic; except for this guy; though he does not offer much in the way of real world tested solutions; more a general observations of 'yeah adhesives can ruin your shoes breathability'. Quote
Members SUP Posted January 31, 2025 Members Report Posted January 31, 2025 What is meant by breathability? Quote Learning is a life-long journey.
Contributing Member fredk Posted January 31, 2025 Contributing Member Report Posted January 31, 2025 29 minutes ago, SUP said: What is meant by breathability? To me; its the ability of a material to allow some air in and out. To allow damp air out of an item made from a material. Leather has no 'breathability'. Canvas deck shoes have loads Quote Al speling misteaks aer all mi own werk..
Members SUP Posted January 31, 2025 Members Report Posted January 31, 2025 (edited) If air and moisture go in and out, it means that water can as well. So leather is either water resistant or breathable. Or, the leather does not absorb water but it lets the water in, through the 'pores' that people seem to be talking about online everywhere. So your shoes are safe but your feet are wet but will dry because of those very same 'pores'. Or am I getting everything wrong @Eelco? Of course, for indoor use, this should not be a problem. Edited January 31, 2025 by SUP Quote Learning is a life-long journey.
Members dikman Posted January 31, 2025 Members Report Posted January 31, 2025 Probably why they developed Goretex and similar materials? Seems to me that any glue applied between two layers of leather is likely to clog the "pores" of said leather. Otherwise there would be no bonding between the layers. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Contributing Member fredk Posted January 31, 2025 Contributing Member Report Posted January 31, 2025 (edited) No. eg A rubber balloon is 'breathable'; it lets air out along with moisture in the air, but it doesn't allow water in I once had a top-level pair of leather motorcycling driving boots; they were 'breathable'. In hot weather they kept my feet cool, by letting out the hot air, but in wet weather they kept my feet dry by not allowing water in Edited January 31, 2025 by fredk Quote Al speling misteaks aer all mi own werk..
Members Eelco Posted February 1, 2025 Author Members Report Posted February 1, 2025 9 hours ago, SUP said: If air and moisture go in and out, it means that water can as well. So leather is either water resistant or breathable. Or, the leather does not absorb water but it lets the water in, through the 'pores' that people seem to be talking about online everywhere. So your shoes are safe but your feet are wet but will dry because of those very same 'pores'. Or am I getting everything wrong @Eelco? Of course, for indoor use, this should not be a problem. Im not sure breathable is a very well defined term; but if you want to get technical about it; yeah there is a difference between convection, as you would get from bulk a bulk gas being pumped around, versus molecular diffusion through the material. Subjectively the net result is the same though; how fast does a given amount of moisture go from one side to the other, and how much moisture will build up inside the shoe. While a solid piece of leather technically is porous, the holes are so tiny that I think the amount of bulk convection through an unbroken piece of leather can be ignored. The way water gets through then, is by dissolving into the leather, diffusing along the leather fibers, and evaporating out at the other end. Same with PVAc; its a solid sheet of rubber without holes, but its a very hydrophilic rubber so water can diffuse through it. Hopefully fast enough to make a difference. Something like neophrene is super hydrophopic though; close to zero water molecules will dissolve into a rubber like that, and close to zero will make it to the other side. Quote
