Hi,
Still have a few motors kicking around the shop - want to make a motorized burnisher out of one of them.
What is the best wood to use for the burnishing wheel ?
Guess it is something like oak or harder - wood is not really my specialty - so any tips will be appreciated.
Have a bud with a wood lathe - but I want to approach him with at least the wood in hand - he likes to moan and groan a lot if has to dip into his own stash - want to avoid that.
Greetings
Hans
I don't think wood is the way to go. I think it's just easier to do. Something like canvas or denim will get you there quicker. I tried felt glued on one of my sanding belts. Wasn't bad but needs work.
Considering a good burnish needs heat I certainly wouldn't go with anything smooth.
Edited by toxo
Wood actually does work great . . . several commercial leather suppliers make and sell them . . .
Mine is I believe out of maple . . . which is the type of wood you want . . . it has a very close grain and is reasonably hard.
Oak can be OK . . . just have to be careful of it . . . sometimes grain can be pretty open . . . which would make for a splinter producer possibly.
When you first start it up . . . 1450 rpms or so is good . . . start it up . . . fold up some old canvas or some cotton rope . . . use it to get the wood warmed up . . . holding it tight into the grooves . . . then add sliced solid bees wax . . . back to the rope . . . more beeswax . . . more rope . . . until you get a really smooth surface.
Fix up some scrap leather . . . edge it . . . rub beeswax on the edge . . . and force it into the grooves while it is spinning . . . and kinda let up slowly on the pressure . . . finish polishing it with an old handkerchief or tee shirt.
Then each time you use it . . . hit it with the beeswax . . . or rub beeswax along the edge of whatever you are burnishing.
You'll love the production.
May God bless,
Dwight
Hi Dwight,
Great - thanks for the tip.
Maple grows here in Europe - thought i had to get some fancy exotic wood - been researching and found sandlewood used --  don´t think that it grows around my neighborhood though.
Beeswax and canvas is no probs either - have lots of bees wax as I make my own leather balm / polish - haven´t bought any commercial stuff for nigh on 25 years now - easy stuff to melt together on any stove and a metal pot.
Been reading other posts and they suggest that they run their burnisher at half speed, which would be pretty close to 3000 rpm - but they didn´t state the burnishing wheel diameter - need that to calculate surface speed in meter per second.    I like the slightly more scientific approach to such matters - makes me feel more confident - which is probably complete "placebo thinking" - but that´s the way i tick.
@ toxo : I will try the belt sander method as well - know of a small manufacturer of sanding belts just out of town - I´ll give them a call and ask if they can´t sell me some belt material before grinding particles are added to the belting - the diagonal cuts at the right length and applying the tape I can manage myself. I´ll just cut an old sanding belt along its´seem as a template.  Maybe even make the whole belt from canvas and ZZ stitch it together. The old Pfaff 138 can produce a pretty wide ZZ.
Greetings
Hans
Edited by Tigweldor
Greetings
Hans
Don't know how to select parts of a thread but the machine I have is in this thread from last year. I just glued some felt to a belt but the felt just stretched out of shape but the potential is really good.
When I was a teenager, I made a slicker from a $2 motor/arbor.   Took a chain saw and cut a slice off of a piece of firewood, drilled a hole and turned it down on the arbor itself.  (Clamped a block of wood to table and used a chisel just like you would on a woodlathe).    The wood turned out to be cherry.  Held up pretty good.  Still have it sitting around somewhere.
There seems to be two similar threads running concurrently. Anyhow, don't overthink it, any reasonably dense wood should do as once you use it a bit the grain/pores should seal up. I've used Australian Jarrah (bloody hard!) and Australian Oak planks (bit softer) which I laminated and turned down to fit my bench grinder. Both work fine. The grinder runs at 2800 rpm, which is really a bit fast but works, 1400 rpm would be better.
