Members bcraig Posted June 15 Members Report Posted June 15 Hi I joined back in 2019 and and had a really good time on the sight. I am back now and got some more questions . I have a piece of 7-9 vegetable tanned leather that has been sitting in the laundry room for close to 3 years,will it still be ok to make a couple of slim Jim Holsters from? It has not been wet nor exposed to the elements. If so I am wanting to make a Slim Jim holster for use to deer hunt with a Pietta Remington 1858 New Army with an 8 inch barrel and just curious whether the slim Jim would make a good holster for my purpose. I am old and disabled and unable to walk very far so I would be useing a truck or a SXS to drive within a hundred yards or so of where I want to hunt on privately owned farm. Then I would walk out to the general area and find a good place to sit down with my back against a big tree,and take the Cap and ball revolver out and sit there until or if I see a deer that I want to take. I am thinking that a Crossdraw Slim Jim Holster would be good for either the truck ride or a SXS ride,I would also want hammer thong in case of a bunpy ride on the side by side and also would feel better about the gun being secure and Unable to have the hammer pulled back by brush or a limb and this combined whith the depth that it would ride in the Slim Jim holster. I also want to make the same type of holster for a Pietta GWII 45 colt / with a 45 ACP convertible cylinder.It has a 4-3/4 inch barrel. I think that both of these revolvers are good looking revolvers so I would not want to unduly rub the finish of of either /also have the 5.5 inch barrel 1858 and the Pietta has a color case hardened finish. Would making the holsters rough side out help along thos lines or be better lined ? I have never made a rough side out or a lined holster and it has been years since I made a holster at all. I would appreciate ya'lls input Quote
Members dikman Posted June 15 Members Report Posted June 15 I have zero experience with using a revolver like you want to (we are only allowed to use pistols at a range, definitely no hunting with them) but from what you've described I would think a Slim Jim should work well. They were originally intended to enable a revolver to be carried safely and to protect the revolver, hence they tend to cover most of it with usually only the grips and hammer protruding. They are also a "minimalist" style without all of the extra bulk of the rear skirt of the later styles so a cross-draw should sit comfortably when driving and again hold the revolver safely. As for the leather, no reason it shouldn't work. The only thing to watch is attaching the belt loop, don't use an uncovered rivet as it will scratch the revolver, better to stitch the loop before folding over to stitch the edge. Anyhow, it sounds like a plan to me. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Dwight Posted June 16 Members Report Posted June 16 We have a lot of the same things going for us. I'm 80 . . . and while I can walk pretty good . . . I don't add extra if I don't have to. Given all of the particulars you mentioned . . . I would not do a cross draw . . . I would do a chest holster . . . with probably a hammer thong to hold it in place. I think could be made so it would fit the 45 as well as the Remington clone. Laugh if you will . . . but I would make the holster for the larger of the two (I'm thinking the Remington would be) . . . and letting it also be used for the 45. If there is a big difference in the barrel length . . . a short piece of wooden dowel could be dropped in the toe of the holster to keep the 45 from falling all the way down in. Tie a slim leather thong to that piece of wood . . . and it could be pulled out for the Remington. Cross draw holsters for large pistols are uncomfortable for me . . . chest holsters are much better . . . but you'll have to make that decision. Making the holster standard or rough out . . . makes little difference unless the flesh side is really rough. Don't add a lot of finish to the inside of the holster . . . as the finish is harder than the leather. Also never leave your weapon in the holster when you come back in. Also keep them minimally oiled . . . as the excessive oil will be picked up by the leather . . . then dust . . . and it will act like sandpaper. For what you are doing you should not need to line it . . . just make it and use it . . . Have fun. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members dikman Posted June 16 Members Report Posted June 16 I didn't think of a chest holster, not surprising seeing that we're not allowed to have them so I haven't tried one but yes, that could work quite well, the down-side is that it will be a lot more complicated to make. It could be a bit daunting for someone without a lot of experience making holsters? Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Dwight Posted June 16 Members Report Posted June 16 2 hours ago, dikman said: I didn't think of a chest holster, not surprising seeing that we're not allowed to have them so I haven't tried one but yes, that could work quite well, the down-side is that it will be a lot more complicated to make. It could be a bit daunting for someone without a lot of experience making holsters? Making a chest holster is really pretty simple as long as one does not get all wrapped up in technicalities. Take this simple picture of a slim jim . . . instead of a flap going down over the belt . . . a slight oval or round part is cut in the pattern to allow the back of the pistol to lay against your chest. Into this oval . . . three tabs are made that simply go thru a "D" ring . . . and on each side of the holster . . . and are riveted thru the oval. I like an inch and a quarter belt going from the D ring as you see it on the right side . . . it goes all the way around your back . . . and attaches with a snap hook to the D ring you see on the left of the picture. Just make it adjustable enough to wear with a Tee shirt or your favorite cold weather hunting coat. Attached to the top D ring is another strap that goes up over your left shoulder if you want to wear it off center . . . or over your right shoulder if you want it to point pretty much straight down between your legs. Personally . . . I prefer the left shoulder . . . it is more comfortable for me. You can put a thumb break . . . a hammer loop . . . or a suicide strap on it to retain the gun . . . and some guys like a loop that goes down to their britches belt to hold it from flopping if you are running or going down hill in the brush. Seriously . . . this is a simple rig to make . . . and I've never had anyone say it is seriously un-comfortable . . . while I have heard that with cross draw holsters. I've also included a similar rig I did for a guy who wanted one for his plastic fantastic pistola. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
CFM chuck123wapati Posted June 16 CFM Report Posted June 16 I carried a 44 in a cross draw for years, then switched to a shoulder holster that sets just about like Dwight's, and I prefer it over the crossdraw. Not as floppy and you can cover it if the weather turns. Easier to drive with too. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members bcraig Posted June 17 Author Members Report Posted June 17 (edited) On 6/15/2025 at 7:54 PM, Dwight said: We have a lot of the same things going for us. I'm 80 . . . and while I can walk pretty good . . . I don't add extra if I don't have to. Given all of the particulars you mentioned . . . I would not do a cross draw . . . I would do a chest holster . . . with probably a hammer thong to hold it in place. I think could be made so it would fit the 45 as well as the Remington clone. Laugh if you will . . . but I would make the holster for the larger of the two (I'm thinking the Remington would be) . . . and letting it also be used for the 45. If there is a big difference in the barrel length . . . a short piece of wooden dowel could be dropped in the toe of the holster to keep the 45 from falling all the way down in. Tie a slim leather thong to that piece of wood . . . and it could be pulled out for the Remington. Cross draw holsters for large pistols are uncomfortable for me . . . chest holsters are much better . . . but you'll have to make that decision. Making the holster standard or rough out . . . makes little difference unless the flesh side is really rough. Don't add a lot of finish to the inside of the holster . . . as the finish is harder than the leather. Also never leave your weapon in the holster when you come back in. Also keep them minimally oiled . . . as the excessive oil will be picked up by the leather . . . then dust . . . and it will act like sandpaper. For what you are doing you should not need to line it . . . just make it and use it . . . Have fun. May God bless, Dwight Hi Dwight I remember you helping me a LOT making a holster for a Bersa Thunder plus ! I will look back at my messages and see when it was. Looks like it was around December 12 2019 !! The years have gone by fast. I am going to have to make the holster for wear on my belt because I have severe neck and back problems,can barely stand to even have a shirt collar on my neck. The Pietta Remington 1858 is much Larger than the Pietta Emf 45 which is the size of a Colt Peacemaker 45 Edited June 17 by bcraig Quote
Members bcraig Posted June 17 Author Members Report Posted June 17 On 6/15/2025 at 6:36 PM, dikman said: I have zero experience with using a revolver like you want to (we are only allowed to use pistols at a range, definitely no hunting with them) but from what you've described I would think a Slim Jim should work well. They were originally intended to enable a revolver to be carried safely and to protect the revolver, hence they tend to cover most of it with usually only the grips and hammer protruding. They are also a "minimalist" style without all of the extra bulk of the rear skirt of the later styles so a cross-draw should sit comfortably when driving and again hold the revolver safely. As for the leather, no reason it shouldn't work. The only thing to watch is attaching the belt loop, don't use an uncovered rivet as it will scratch the revolver, better to stitch the loop before folding over to stitch the edge. Anyhow, it sounds like a plan to me. Thanks ,I appreciate your input. Quote
Members bcraig Posted June 17 Author Members Report Posted June 17 20 hours ago, chuck123wapati said: I carried a 44 in a cross draw for years, then switched to a shoulder holster that sets just about like Dwight's, and I prefer it over the crossdraw. Not as floppy and you can cover it if the weather turns. Easier to drive with too. Yes I can see some afvantages but like I was telling Dwight I cant bear to wear a shoulder rig anymore. If the Weather turns I am coming out of the woods as fast as I can and geyying in the Truck or side by side ! And if it does not catch me by suprise I will be sitting in the truck before the first raindrop hits,hopefully ! Thanks for your input to,I appreciate it. Quote
Members bcraig Posted June 17 Author Members Report Posted June 17 (edited) On 6/15/2025 at 6:36 PM, dikman said: I have zero experience with using a revolver like you want to (we are only allowed to use pistols at a range, definitely no hunting with them) but from what you've described I would think a Slim Jim should work well. They were originally intended to enable a revolver to be carried safely and to protect the revolver, hence they tend to cover most of it with usually only the grips and hammer protruding. They are also a "minimalist" style without all of the extra bulk of the rear skirt of the later styles so a cross-draw should sit comfortably when driving and again hold the revolver safely. As for the leather, no reason it shouldn't work. The only thing to watch is attaching the belt loop, don't use an uncovered rivet as it will scratch the revolver, better to stitch the loop before folding over to stitch the edge. Anyhow, it sounds like a plan to me. Thanks,I am not going to be using any rivets, just sewing a loop to the back of the holster before stitching the edge. Wonder if I need to use a welt given the weight of the leather I will be using? Edited June 17 by bcraig Quote
