AlZilla Posted July 18 Report Posted July 18 I have an inexpensive, generic servo motor that got damaged in transit. The seller credited it back and told me to keep it. Once the replacement gets here, I'll get it off the machine and take it apart. The motor works but rattles and thumps. The tighter the belt, the louder. I'm thinking a damaged front bearing (the damage was a very hard shot to the pulley area that drove it through the styrofoam and cardboard). Also, how interchangeable are the control boxes? The wiring and pinouts of every one I've had my hands on is the same. I'm thinking maybe a higher rated box, say 750 watts, might be ok running a 550 watt motor? Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Members dikman Posted July 18 Members Report Posted July 18 Regarding the control box if it's the same brand and the menus/settings are the same then there's a pretty good chance they will be interchangeable. The motor, being cast alloy, may have a broken bit of the housing inside? Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Cumberland Highpower Posted July 19 Members Report Posted July 19 (edited) 2 hours ago, AlZilla said: I have an inexpensive, generic servo motor that got damaged in transit. The seller credited it back and told me to keep it. Once the replacement gets here, I'll get it off the machine and take it apart. The motor works but rattles and thumps. The tighter the belt, the louder. I'm thinking a damaged front bearing (the damage was a very hard shot to the pulley area that drove it through the styrofoam and cardboard). Also, how interchangeable are the control boxes? The wiring and pinouts of every one I've had my hands on is the same. I'm thinking maybe a higher rated box, say 750 watts, might be ok running a 550 watt motor? Sounds like a bent shaft, but could be a bent pulley as well? I doubt it a bad bearing though. A damaged bearing would make a rumble or a bit of vibration from the brinelling caused by the impact but that's about it. Edited July 19 by Cumberland Highpower Quote
AlZilla Posted July 19 Author Report Posted July 19 Hmm... I'm anxious to take it apart. The pulley doesn't wobble. I'm surprised nobody has taken one apart but I can't find anything online. Yet. A week or two, I guess. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Members Cumberland Highpower Posted July 19 Members Report Posted July 19 Just a thought, but if your pulley doesn't wobble and the shaft appears to have no runout, is your belt having a bad section? Just thinking of all options. Quote
CFM chuck123wapati Posted July 19 CFM Report Posted July 19 14 hours ago, AlZilla said: I have an inexpensive, generic servo motor that got damaged in transit. The seller credited it back and told me to keep it. Once the replacement gets here, I'll get it off the machine and take it apart. The motor works but rattles and thumps. The tighter the belt, the louder. I'm thinking a damaged front bearing (the damage was a very hard shot to the pulley area that drove it through the styrofoam and cardboard). Also, how interchangeable are the control boxes? The wiring and pinouts of every one I've had my hands on is the same. I'm thinking maybe a higher rated box, say 750 watts, might be ok running a 550 watt motor? i've seen electric motors break the fan blades located in the rear of the housing They make quite a racket sometimes, i dont know if your motor has one. the blades are usually plastic and can come loose or break. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
AlZilla Posted July 19 Author Report Posted July 19 4 hours ago, Cumberland Highpower said: Just a thought, but if your pulley doesn't wobble and the shaft appears to have no runout, is your belt having a bad section? Just thinking of all options. No, definitely not a belt. It makes a small winding/grinding sound with no belt. A belt makes it worse and more tension increases the noise. To @chuck123wapati's point about the fan, even if it isn't a bad fan, I'm going to dig up a small 5 VDC computer fan, point it into the motor housing and plug it in to the LED socket on the control box. One thing consistently said about these things is that they make heat at low speeds, exacerbated by the fact that the fan is running slowly. That should be easily solved. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
AlZilla Posted July 19 Author Report Posted July 19 About 8 minutes into this video, the guy has replaced the front bearing and is resetting the encoder. I wonder if one of those little plastic parts cracked/moved/whatever. The electronics of it still work. Now I really want to take it apart. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Members GerryR Posted July 19 Members Report Posted July 19 23 hours ago, AlZilla said: I have an inexpensive, generic servo motor that got damaged in transit. The seller credited it back and told me to keep it. Once the replacement gets here, I'll get it off the machine and take it apart. The motor works but rattles and thumps. The tighter the belt, the louder. I'm thinking a damaged front bearing (the damage was a very hard shot to the pulley area that drove it through the styrofoam and cardboard). Also, how interchangeable are the control boxes? The wiring and pinouts of every one I've had my hands on is the same. I'm thinking maybe a higher rated box, say 750 watts, might be ok running a 550 watt motor? You can run the 550 watt motor from the 750 watt control unit. The other way is not advisable (750 watt motor on a 550 watt controller) unless you know you won't exceed the 550 watt load. Quote
AlZilla Posted July 19 Author Report Posted July 19 1 hour ago, GerryR said: You can run the 550 watt motor from the 750 watt control unit. The other way is not advisable (750 watt motor on a 550 watt controller) unless you know you won't exceed the 550 watt load. That's kind of what I suspected. I wonder if some of the other parameters aren't arbitrary, too. Example, lowest startup speed. One motor will drop down to 100 rpms, while another stops at 200. If you go to ebay and search for servos, lots of the listings will have pics that include a QR code on the motor and/or box. Scan it with your call phone camera and they ALL drop to the same spec sheet. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
