Northmount Posted July 20 Report Posted July 20 2 hours ago, AlZilla said: One motor will drop down to 100 rpm, while another stops at 200. May also depend on number of coils (magnetic poles). On 7/18/2025 at 7:16 PM, AlZilla said: The pulley doesn't wobble. Did you measure with a dial gauge, or brace a pencil and bring it close to the pulley until it just touches some point on the side of the pulley rim while turning by hand, and also when running the motor? 8 hours ago, AlZilla said: No, definitely not a belt. It makes a small winding/grinding sound with no belt. A belt makes it worse and more tension increases the noise. Tends to say the bearing may be damaged (possible broken or cracked outer race or deformed balls), or if the bearing is supported by spokes vs. machined full face like the video shows and 1 or more spoke is broken. This is definitely a mechanical issue (due to hearing and feeling grinding noise speed and belt tension changes). Reminds me off a vibration analysis job on a large cooling water pump. Driver was a steam turbine running around 7000 RPM. The story came together in pieces. You only get told what they think is relevant. The turbine had tripped on overspeed. They rebuilt the governor and put it back together. Now it had high vibration. They had a spare turbine rotor in storage so swapped it out. Still had high vibration. Then they called me. I took vibration measurements on the turbine, gear reduction box, and the pump. The pumps operating speed was about 500 rpm. The vibration on the high speed pinion shaft was approaching 100 in/sec, fantastically high and dangerous. (1 in/sec is bad.) I got out of there as quickly as I could while capturing the necessary vibration data. The vibration frequency spectrum showed peaks at the turbine speed and at the pump speed. The highest peak was at the pump speed. So I told them the pump / bull gear shaft was bent. They replaced the gear box. Still a problem. Told them they needed to check the run out on the pump shaft. Guess what, it was bent. Then comes the rest of the story. A board (slat) had fallen off the cooling tower and was sucked into the pump. Oh! that is interesting! The board had stalled the pump and broke up. The turbine governor had opened up wide open to bring the speed back up. As the board broke up, the turbine went overspeed and tripped before the governor could correct the speed. The board bent the pump shaft before the board broke up. The unit was about 1200 hp. Pump suction was about 20" or so diameter. Quote
AlZilla Posted July 20 Author Report Posted July 20 10 hours ago, Northmount said: Did you measure with a dial gauge, or brace a pencil and bring it close to the pulley until it just touches some point on the side of the pulley rim while turning by hand, and also when running the motor? I didn't try it powered but I did hold a flat blade screw driver next to it and then slide it under. It doesn't show any wobble, at least at hand spinning speeds. A runout gauge is not in my bag of tricks. I might have to go tear it apart before the replacement arrives. I really don't want to run it anyway. No need of doing more damage. And I'm pretty curious. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Members dikman Posted July 21 Members Report Posted July 21 Definitely pull it apart, we're all interested now to see what the problem is! Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Cumberland Highpower Posted July 21 Members Report Posted July 21 (edited) On 7/20/2025 at 8:19 AM, AlZilla said: I didn't try it powered but I did hold a flat blade screw driver next to it and then slide it under. It doesn't show any wobble, at least at hand spinning speeds. A runout gauge is not in my bag of tricks. I might have to go tear it apart before the replacement arrives. I really don't want to run it anyway. No need of doing more damage. And I'm pretty curious. In reality, other than testing a damaged pulley, that trick wouldn't do enough most likely to show what's bad. Bearings are precision units (even cheap bearings) and you could have enough bearing damage or runout in the shaft to cause issues and not be able to tell with a screwdriver. A possible "possibility" is that maybe the shaft was "driven" backwards a little, enough to cause something to rub inside? If that was the case would be an easy fix I'd think? If it is a bad bearing, I'd almost gamble its the rear bearing rather than the front. Edited July 21 by Cumberland Highpower Quote
Contributing Member friquant Posted July 28 Contributing Member Report Posted July 28 This is the stator and rotor from my "stitchman" digital servo. Only took about fifteen minutes to get it apart with a #2 philips on the screw gun, then a screwdriver and wrench to pry the plates off. Those permanent magnets are no joke! Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
Contributing Member friquant Posted July 29 Contributing Member Report Posted July 29 When I was in there, I found three hall sensors in position to read the permanent magnets of the rotor as they go by. I should have worn gloves when I put it back together...those magnets are vicious, and I got pinched. Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
Members dwhacks Posted August 3 Members Report Posted August 3 Have you gotten anywhere with this? I bought an "open box" motor from amazon that is noisy like you describe. More under more tension or load. Quote
AlZilla Posted August 3 Author Report Posted August 3 The executive summary at this point is that I believe the noise is in the bearings, but taking it apart and reassembling it quieted it down by more than half. My current theory is bearing damage and the case was torqued out of alignment by the beating it took in transit. I've taken it apart and examined it to the best of my ability and tools. I find nothing with excessive runout out or bent out of detectable shape. I took high res photos to look for cracks and found none. I've ordered bearings which arrive tomorrow. I need to get an appropriate puller as all mine are automotive type. The bearings are 15mm id, 9mm wide and 32mm od. 6002-rz is the part number and they're available for a few bucks each on Amazon. I'll upload pictures of the disassembly for the next hapless adventurer. Further updates when I get around to swapping the bearings. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
AlZilla Posted August 10 Author Report Posted August 10 I still need to get pictures posted but I can report SUCCESS repairing this motor! I replaced both bearings and it sounds fine now. Very easy job with a small gear/bearing puller. The bearings seat against a stop on the shaft, so zero worry about getting them back in position. I'll say that getting the case back together correctly takes patience and a gentle touch. Each end is very tightly fitted to the case. It takes very gentle tapping to get them seated all the way and then slowly tightening the 4 screws on each end in a repeated cross pattern. I believe that part of my original noise was from the case being misaligned due to the beating it took in transit. I wouldn't hesitate to do this job again. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
