Members Ed Neil Posted August 1, 2025 Members Report Posted August 1, 2025 I just got a singer 132k6 what would be the heaviest tread and needle it can use i set it up wit a 750 w servo mottor since thw one ii had eather capasitor may be bad or the hile mottor its a bit confusing since the mottor is 120v the capacitor is 330v and the box where the on and capacitor and of on and off swich is is calling for 250v. (Transmiter mottor and swich+capacitor). The leather belts slips from time to time. Quote
Contributing Member friquant Posted August 1, 2025 Contributing Member Report Posted August 1, 2025 Can you send us pictures of your current setup? (Motor, pulley, belt, machine) Also photos of your old motor, control box, and nameplate if it has one? (If you want help diagnosing the old motor, that is) 4 hours ago, Ed Neil said: The leather belts slips from time to time. New leather belt? Old leather belt? I like having my belt tension set just high enough to go through my thickest material, that way I'm less likely to break things. My belt is not very grippy, but I'm considering getting a regular rubber automotive belt instead of these cloth-covered belts I've been using. Not sure what other folks are using for belts. Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
Members dikman Posted August 1, 2025 Members Report Posted August 1, 2025 Don't worry about the old motor, replacing it with a servo is a smart move. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Contributing Member friquant Posted August 1, 2025 Contributing Member Report Posted August 1, 2025 @Wizcrafts blogged about the 132k6 in his My history with leather sewing machines blog Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
Members Constabulary Posted August 2, 2025 Members Report Posted August 2, 2025 (edited) basically it depends on the size of the needle hole in the needle plate. I never tried to max out what it can sew but 207 / 277 thread with # 24 /25 needle is not a problem with mine. Edited August 2, 2025 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Ed Neil Posted August 2, 2025 Author Members Report Posted August 2, 2025 Im hoping to use 346 bonded poliester looking for a suplier fo apropiate needles 216x1 or equivalent. Quote
Members Ed Neil Posted August 2, 2025 Author Members Report Posted August 2, 2025 On 8/1/2025 at 9:48 AM, Ed Neil said: I just got a singer 132k6 what would be the heaviest tread and needle it can use i set it up wit a 750 w servo mottor since thw one ii had eather capasitor may be bad or the hile mottor its a bit confusing since the mottor is 120v the capacitor is 330v and the box where the on and capacitor and of on and off swich is is calling for 250v. (Transmiter mottor and swich+capacitor). The leather belts slips from time to time. Quote
Members dikman Posted August 2, 2025 Members Report Posted August 2, 2025 Looks like you've threaded it with small rope! Swapping out the motor and wiring is a smart move as given its age there is a possibility that the electrical insulation could break down, plus the capacitor is probably dried out inside. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
AlZilla Posted August 2, 2025 Report Posted August 2, 2025 You should probably go read Wizcrafts experience posted above. Looks like he got 346 though it but only after a fashion. Might want to pick his brain directly with exactly what you want to do before spending a lot of time and money. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Contributing Member friquant Posted August 3, 2025 Contributing Member Report Posted August 3, 2025 Re: Clutch motor It's a 110V motor. It's normal/fine for switches and capacitors to be rated for higher voltage that the actual use case. But even if you did want to use a clutch motor, this is not the one to use because it's a 2-pole motor (3500rpm) instead of the 4-pole variety which are only 1750rpm. Good move on the digital servo. Is it a cylindrical shaft 15mm diameter? If so, you can get a 45mm pulley for that here: https://www.ebay.com/itm/376135081840 which will slow it down considerably. Re: Belt slipping I would buy a new belt. The belt looks all dried out (less grip) and looks to be too narrow for that pulley. V-belts need to be pressing against the walls of the pulley to get the best grip. I've been buying belts like this one: https://www.amazon.com/dp/B0BK1FQHRR but I suspect that a 3/8" automotive (rubber on the outside) belt would be the grippiest. Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
