toxo Posted August 19, 2025 Report Posted August 19, 2025 (edited) 53 minutes ago, dikman said: Haven't used it yet. I've been trying to find where to buy the steel rule to make my own dies, no success yet. All the searches point me to either the US or China (alibaba), neither of which is feasible. I've found someone selling hoop (banding) steel pretty cheap so might give that a try. It's the same size as 2pt steel rule so it's worth a try. I also have to make a device for bending/shaping the stuff. But the Vevor is a nicely made tool, built like a tank! I assume the UK is too dear also? I did a post a while back about this where I posted a link to Partwell. Usually sold in packs of 60/100 so heavy. Better off looking for die makers who might sell you some. Edited August 19, 2025 by toxo Quote
Members dikman Posted August 19, 2025 Members Report Posted August 19, 2025 12 hours ago, toxo said: I assume the UK is too dear also? I did a post a while back about this where I posted a link to Partwell. Usually sold in packs of 60/100 so heavy. Better off looking for die makers who might sell you some. Even that is proving problematic, Australia is a strange market......I'll try the banding steel, it may not have enough carbon in it to get a hardened edge but should still hold an edge adequate for cutting leather. It's cheap enough ($5 a roll) to experiment with. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
toxo Posted August 19, 2025 Author Report Posted August 19, 2025 14 hours ago, dikman said: Even that is proving problematic, Australia is a strange market......I'll try the banding steel, it may not have enough carbon in it to get a hardened edge but should still hold an edge adequate for cutting leather. It's cheap enough ($5 a roll) to experiment with. Another factor with postage is they come in 1 meter lengths. Shame you weren't nearer I would've sorted you out a few lengths. I've even got an almost full pack of 3 point somewhere that my cheapo bending gear won't handle. If that banding gear is a bit springy you might have trouble with straight lines. (unless you're putting it around a wooden block and then fixing it might be a problem cos you have to leave enough sticking out to cut the leather.) Toxo, that is very thoughtful of you. I just went for a drive and bought some steel banding. It's 0.7mm thick by 30mm wide and the rolls are between 20 - 30 metres long. They are leftovers from the manufacturing process, they get huge rolls of the stuff, approx. 1 metre wide, and slit it to 30mm and these are the bits left after coiling it to measured lengths. The stuff is used for building steel-framed houses, is very good quality and is high-tensile. It's going to be interesting to see what I can do with it. I'll probably try making wooden shapes to attach it to, but the first thing is to build some sort of jig for bending it. 6 hours ago, dikman said: Toxo, that is very thoughtful of you. I just went for a drive and bought some steel banding. It's 0.7mm thick by 30mm wide and the rolls are between 20 - 30 metres long. They are leftovers from the manufacturing process, they get huge rolls of the stuff, approx. 1 metre wide, and slit it to 30mm and these are the bits left after coiling it to measured lengths. The stuff is used for building steel-framed houses, is very good quality and is high-tensile. It's going to be interesting to see what I can do with it. I'll probably try making wooden shapes to attach it to, but the first thing is to build some sort of jig for bending it. That sounds like it's gonna work. Rule steel is only 0.7 also but likely to be harder. If you go with a precise wooden core and a softish board I'd say you have a good chance. This is very handy for the holes if you go with wood. I've seen them cheaper than I paid. When I started it was with a large vice, 2 six inch nails and a hammer. Worked well for simple shapes. This is a mini rolling mill that was really cheap, very heavy and won't do very small circles but good for circular handbag styles. Can't remember where I got it. Quote
Northmount Posted August 20, 2025 Report Posted August 20, 2025 Split this batch of posts off of Clicker Dies, No Clicker Press? as these posts are about making dies. Quote
Members dikman Posted August 21, 2025 Members Report Posted August 21, 2025 I played around with a piece of the banding and it looks promising. It's pretty tough and springy but can be hammered into a right angle without snapping. Heating it to anneal it makes no difference, as does heating and quenching. It can be filed to give a sharp edge but obviously won't be quite as hard as the proper steel rule. I also have a hand tool that is used to punch/crimp the banding to the steel house framing (I had no idea what to do with it but for $5 at the time it just looked useful ), it punches a rectangular hole but I should be able to make a new pin and anvil to punch a small round hole. My biggest challenge though is to make a bending jig/machine to shape the stuff. It won't be difficult, just a matter of digging through all my "stores" to see what can be re-purposed. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
1hp Posted August 21, 2025 Report Posted August 21, 2025 these work pretty well. https://durston.com/product/ring-shank-bender/ Quote
toxo Posted August 21, 2025 Author Report Posted August 21, 2025 55 minutes ago, 1hp said: these work pretty well. https://durston.com/product/ring-shank-bender/ That's the one I've got. Handles 2pt but not 3pt. Should be good on your banding dikman. I use a longer piece of tubing over mine. Quote
Members dikman Posted August 21, 2025 Members Report Posted August 21, 2025 Harry Rogers used one of those but I didn't know what it was called, apparently designed for jewellery work. It looks like it's for material about 25mm high(?) but my stuff is about 32mm. They're also very expensive here, maybe $600 or so. Temu have a version for $35 but it looks like it's even smaller. It wouldn't be hard to make something that operates on the same principle but it depends on what I've got in the scrap bin. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
toxo Posted August 21, 2025 Author Report Posted August 21, 2025 I honestly did start out with a big vise and a couple of six inch nails and I got reasonably good at it, only because I was fitting around a solid wooden core and lots of screws around the outside helped to get it into shape. And of course I was using 3pt R/Steel at the time so your stuff should be easier. Quote
Members dikman Posted August 22, 2025 Members Report Posted August 22, 2025 Scratching around and this is what's coming along. the base is a lump of heavy channel iron, the blue piece will be welded to the angles which will give it some bottom clearance, the rusty square tube will slide inside with a handle on the left. I'm not sure whether I will need to make a compound linkage for the handle. The little square piece on the right will hold one part of the die and will slide into the other piece with a locking pin to hold it. This way I can make interchangeable dies. The other half of the die will be attached to round stock and will fit into a hole in the channel base. At least, that's the theory. Worst part of the job next, removing all the rust before welding, wire wheels and sandblasting I guess. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
