Members Danotriglide Posted 10 hours ago Members Report Posted 10 hours ago Hi everybody, Newbie here trying to sew pigskin. Singer 6700C machine with polyester upholstery thread and “leather sewing needles”. Thin pigskin about same thickness as poster paper. Problem is the thread starts shredding kind of and bunches up right before it goes thru the eye. It tries to lift the presser foot when the needle goes upstroke. Eventually it will choke if I keep going. Thanks, Dano Quote
AlZilla Posted 10 hours ago Report Posted 10 hours ago More foot pressure might help the lifting. Does it sew cloth without shredding? How about the thread and needle size? Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
kgg Posted 9 hours ago Report Posted 9 hours ago 7 minutes ago, Danotriglide said: Newbie here trying to sew pigskin. Singer 6700C machine with polyester upholstery thread and “leather sewing needles”. Thin pigskin about same thickness as poster paper. Problem is the thread starts shredding kind of and bunches up right before it goes thru the eye. It tries to lift the presser foot when the needle goes upstroke. Eventually it will choke if I keep going. What size of thread are you trying to use??? The max size of needle ( #18 / 110 ) in the manual indicates it could handle maybe V69. Even through the machine could handle the same thickness of fabric when you are dealing with any type of leather or thickness the machine is going to struggle. In a nut shell this is the Wrong machine that was made / designed for fabric. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Danotriglide Posted 8 hours ago Author Members Report Posted 8 hours ago (edited) Hers some pics, changing needle to 100/16 to try. Thread is nylon upholstery thread. I’m not sure of size there’s some numbers on spool. Sews fabric perfectly. Edited 8 hours ago by Danotriglide Quote
Members Danotriglide Posted 8 hours ago Author Members Report Posted 8 hours ago Changing needle seemed to work! Quote
Members Danotriglide Posted 7 hours ago Author Members Report Posted 7 hours ago But now it’s doing this, took off walking foot but this is just two scraps. Quote
Northmount Posted 6 hours ago Report Posted 6 hours ago 3 hours ago, Danotriglide said: Newbie here trying to sew pigskin. I moved your post to Leather Sewing Machines Quote
AlZilla Posted 6 hours ago Report Posted 6 hours ago To me, that shredding still looks like the needle is too small for the thread. If that thread came from a regular fabric store, I wouldn't think it's bigger than v69. According to this handy chart it wants a 16 OR 18 needle. Maybe an 18 will solve the shredding. How about trying some smaller thread with your size 16 needle on some scrap? It might prove the concept. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Moderator Wizcrafts Posted 5 hours ago Moderator Report Posted 5 hours ago 4 hours ago, Danotriglide said: Hi everybody, Newbie here trying to sew pigskin. Singer 6700C machine with polyester upholstery thread and “leather sewing needles”. Thin pigskin about same thickness as poster paper. Problem is the thread starts shredding kind of and bunches up right before it goes thru the eye. It tries to lift the presser foot when the needle goes upstroke. Eventually it will choke if I keep going. Thanks, Dano The largest needle commonly available for domestic sewing machines is a #18/110. I once found some #20 needles for an old iron body Singer from yesteryear. Those machines held up much better than the plastic body machines of today. I mentioned this because most so-called Upholstery thread is #69 bonded nylon. This size is normally sewn using a #18 (Metric 110) needle. Leather point needles work best on leather, as opposed to round points. You should be able to get a decent stitch using #69 thread with a #18 needle by balancing the bobbin vs top tension and enough foot pressure to keep the leather from lifting with the ascending needle. But, if you plan to sew leather on a regular basis, buy an iron body walking foot machine that's mounted on a 20 x 48 inch industrial k-legs frame and table and powered by a 3/4 HP servo motor. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Danotriglide Posted 4 hours ago Author Members Report Posted 4 hours ago Thanks everybody! With the thread I have and a 110-18 needle it’s working good! I’m traveling slow but somewhat erratic on this practice piece. Will check the chart! Thanks! Dano Quote
