Members HondoMan Posted November 7 Members Report Posted November 7 Right then, Hand-sewing in zips. This really does get under my skin. I do them, but it brings me no pleasure. The problem surrounds the gluing in. I have tried contact glue as well as PVA. Neither of these adhere to the zip material. Ok, a wee bit. But I found the zip moves, which creates an non-straight zip. I have been using a double sided tape for the past couple of years. This does work well keeping the zip in place; however, the adhesive is all over my awl and needles. Urgh! Now I have to wipe the residue from the tape off my awl and needles about every five holes. The residue and tape also do not allow the awl or needles to move smoothly through the leather. There has to be a better method. Some type of adhesive that will keep the bleedin zip still and won't smear adhesive all over the tools. Ideas? Cheers! Quote http://lederwaren-allgäu.de/ https://www.instagram.com/scottishknightleather/
toxo Posted November 7 Report Posted November 7 30 minutes ago, HondoMan said: Right then, Hand-sewing in zips. This really does get under my skin. I do them, but it brings me no pleasure. The problem surrounds the gluing in. I have tried contact glue as well as PVA. Neither of these adhere to the zip material. Ok, a wee bit. But I found the zip moves, which creates an non-straight zip. I have been using a double sided tape for the past couple of years. This does work well keeping the zip in place; however, the adhesive is all over my awl and needles. Urgh! Now I have to wipe the residue from the tape off my awl and needles about every five holes. The residue and tape also do not allow the awl or needles to move smoothly through the leather. There has to be a better method. Some type of adhesive that will keep the bleedin zip still and won't smear adhesive all over the tools. Ideas? Cheers! Stapler! Not the office type, the plier type. Use anywhere the holes are not seen. Simply remove after they've done their job. Office/Work/Home Stapler - Foska Plier Grip Stapler ST0512 - Black | eBay UK Quote
Northmount Posted November 7 Report Posted November 7 11 hours ago, HondoMan said: Hand-sewing in zips Moved your post to Sewing Leather Quote
Digit Posted November 24 Report Posted November 24 (edited) The way I learned it is with double-sided tape (the narrowest you can find; I use 3mm), but stick the tape to the outer edges of the zipper's fabric tape and (machine) sew next to it. _________________________________________ edge of zipper tape ========================================= double sided tape ......................................... stitch line ----------------------------------------- edge of leather """"""""""""""""""""""""""""""""""""""""" zipper teeth So you basically sew next to the double-sided tape instead of through it. Edited November 24 by Digit Quote
Members BlackDragon Posted November 24 Members Report Posted November 24 1 hour ago, Digit said: The way I learned it is with double-sided tape (the narrowest you can find; I use 3mm), but stick the tape to the outer edges of the zipper's fabric tape and (machine) sew next to it. _________________________________________ edge of zipper tape ========================================= double sided tape ......................................... stitch line ----------------------------------------- edge of leather """"""""""""""""""""""""""""""""""""""""" zipper teeth So you basically sew next to the double-sided tape instead of through it. This is what I do. I use 1/4" (6mm) double sided tape, if you don't have thin tape you can cut wider tape down the center long ways. Quote
Members HondoMan Posted November 27 Author Members Report Posted November 27 On 11/24/2025 at 2:34 PM, Digit said: The way I learned it is with double-sided tape (the narrowest you can find; I use 3mm), but stick the tape to the outer edges of the zipper's fabric tape and (machine) sew next to it. _________________________________________ edge of zipper tape ========================================= double sided tape ......................................... stitch line ----------------------------------------- edge of leather """"""""""""""""""""""""""""""""""""""""" zipper teeth So you basically sew next to the double-sided tape instead of through it. Good idea. I'll give it a wee go. Cheers! Quote http://lederwaren-allgäu.de/ https://www.instagram.com/scottishknightleather/
