Got a great deal on a Juki LU-563.  Essentially a one-owner machine that has spent the last 10-15 years in storage.  It is tight and free, but it will obviously need to be oiled and checked out before being put into use.
Most of the discussions on this forum seem to deal with damaged or broken machines.  This one appears to be in remarkably good condition.
My question is:  Does the machine need to be completely disassembled?  I have not yet found a service manual, and I'm hoping not to have to take it apart using a parts diagram.
Thanks in advance for thoughts on how to proceed.
Well, the good news is that you probably don't have to take it all apart. and you might just be able to oil it and go.  Some pictures would help us to to evaluate it.  Maybe a video walk around.
Do you have the whole machine, table,motor and all? Or just a head unit?
For starters, I'd oil it everywhere metal moves against metal. All the oiling points on top, everyplace underneath that a bushing, bearing or anything else moves metal on metal.  Turn it over by hand and let it sit for a day.  If you have the whole setup, motor and all try running it and give it a listen.
When I got my first industrial, it turned over a lot harder than any domestic i had worked with. I had no idea how tight it should have been so I erred way on the side of caution and flushed PB Blaster through everything followed by sewing machine oil. Turned it endlessly by hand trying to decide if it was too tight. I removed the internal belt so I could evaluate the top and bottom separately. After a week or so of this activity, turned out it was fine to begin with.
- Voltaire
- Aristotle
NO,don't ever take it apart,just oil everything & use it.It will loosen up as you use it.
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Thank you all for the input - that is wonderful news!  Yes, I have the table, but it needs a thorough descaling, paint, and a new top.  Bob, I will be ordering a Consew servo motor soon.
That looks like a win to me. It's a pretty close clone of the Singer 111w156, if not identical. Parts and information are going to be abundant and easily found.
Look for the user instructions. If the 156 isn't easily found, the 111w155 will be close enough for the oiling points.
You know that journey of a thousand miles that begins with a single step?  You just took that step. Welcome to the rabbit hole.
EDIT: Here's the 156 manual. It'll get you started.
111w156.pdf
- Voltaire
- Aristotle
- Voltaire
- Aristotle
It cleaned up very well and runs smoothly.  After a thorough clean, I blew air in it to dry it out and was rewarded with what looked like a full bag of sunflower seed hulls.  Guess somebody was living inside it!  I'm very happy with how it is turning out.  Thanks all for the encouragement.
That's identical to my Seiko stw 28b , which is a twin needle machine, but I only use it as a single needle machine.
Mine was under a tarp on a verandah for quite a while and a bit exposed to the elements, I just oiled everything up and turned it gently by hand before I started it up, i had to fiddle around for a while,  it needed a few adjustments,  but works fine now.
I can't find a manual for mine either. So I use a manual for a consew machine only as a guide.
Good luck 👍
HS
' I have a very gweat friend in Wome called Biggus Dickus,
He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '  :rofl:
I picked-up a few machines in past years that were good shape, but stored longtime and bone dry. I did nothing more than wipe-down, remove all covers, and set the head on metal flat pan. I just 'heavily oil' every moving part. Then just let it sit for days with rolling it by hand every once while every day. After that I just check it out, like bobbin assembly, hook, timing, thread routing, feet and feed,..etc .. Then string it-up and see how it stitching.
After that you can start working out all the little bugs, and getting the table/drive situation worked-out . But I have found for most part, if nothing is obviously BAD broken. Old industrial machines don't take to much of your time to get back to running condition .
