Members catskin Posted November 21 Members Report Posted November 21 It's been a while since I was here. I have gotten a 29k58 machine. For some unknown reason a previous owner took out the front shaft that allows for the balance wheel to be mounted on the front. The hub is still there. The part numbers are 82008 for the shaft and 81869 for the gear. From the research I have done so far it seems that those parts are the same on most if not all Singer patchers. Can anyone tell me if they know if those parts are still available, even used. And if the parts from an Adler or some clone would fit. Quote
Members Constabulary Posted November 21 Members Report Posted November 21 (edited) college sewing in the UK for sure has the parts. I have used them for my 29k71 back then. But the parts where tight and IIRC the shaft had no hole for the tapered pin that holds the bevel gear. But I may have some used parts. Please send em a message. Where are you located? Edited November 21 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Moderator Wizcrafts Posted November 21 Moderator Report Posted November 21 50 minutes ago, Constabulary said: Where are you located? His ip address shows that he is in Canada. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Northmount Posted November 22 Report Posted November 22 23 hours ago, Constabulary said: Where are you located? Also shows Saskatchewan Canada in his profile. Quote
Members Constabulary Posted November 22 Members Report Posted November 22 either I haven't noticed it or it has been added lately 😉 no big deal.... Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members catskin Posted November 23 Author Members Report Posted November 23 Yes, I had my location added after my first post. Hoping it might get replies from closer. Quote
Members catskin Posted Monday at 07:36 PM Author Members Report Posted Monday at 07:36 PM On 11/21/2025 at 11:04 AM, Constabulary said: college sewing in the UK for sure has the parts. I have tried many times to contact Collage sewing and always get a message invalid phone number. what can I be doing wrong? I searched google on how to enter a phone number to another country and doing that did not work either. Quote
