Members dikman Posted November 25, 2025 Members Report Posted November 25, 2025 After seeing one of these on Road Agent Leather's latest video I just had to get one! Although I have a couple of belt grinders this one looked ideal for leatherwork - it's fairly compact, portable, uses 1" x 30" belts and is variable speed. This one is sold by Vevor and the quality looks very good. It uses a sewing machine servo motor (550w) and a modified control box. It's got some grunt behind it, I pushed a piece of steel into the belt -hard - and it didn't slow down. Impressive. 4"contact wheel, platen and best of all it can be tilted horizontal. First thing to do is make a larger base for it and then make a longer tool rest which will be better when it's used horizontally. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Dwight Posted November 25, 2025 Members Report Posted November 25, 2025 If you do many belts . . . like me . . . you'll find you are changing that 30 inch rascal all too often. I still use both of the two I've got . . . but just as soon as I can get some of the junk work out of my hair . . . I'm going for a 2 x 72 inch knife grinder . . . with a bit less than 5 times the belt surface . . . I'm looking to get 5 times the use out of it . . . plus the 2 inches wide will do better than the 1 inch I'm now using. But I do like your rig . . . and if I did any real serious wood working . . . I'd be very much interested in one of those May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Moderator bruce johnson Posted November 25, 2025 Moderator Report Posted November 25, 2025 Interesting timing, I ordered one this morning. Even with two 2x72 belt grinders and a 2x48 belt grinder, I still drag out my trusty 1x30 Harbor Freight pretty often. The HF has paid for itself many times over, but on it's last lap. I was going to replace it with another HF until I saw the variable speed option on the Vevor. I do like my variable speeds.... BTW for belts - Combat Abrasives, Red Label, and TruGrit all have a ton of options for 1x30 belts in grits ranging from iron munching flesh eaters to insanely fine grits. I get abrasive, conditioning, and leather stropping belts from a mix of all these folks. Quote Bruce Johnson Malachi 4:2 "the windshield's bigger than the mirror, somewhere west of Laramie" - Dave Stamey Vintage Refurbished And Selected New Leather Tools For Sale - www.brucejohnsonleather.com
Members dikman Posted November 25, 2025 Author Members Report Posted November 25, 2025 Yep, for anyone who does full-time leatherwork a 2x72 (or 2x48) grinder is the only way to go if you want a grinder. For me this has the advantage that I can easily move it wherever I want so I can keep all the fine dust outside, something I can't do with my other belt grinders. I also have a small wheel attachment for the 2x48 and I intend modifying it so I can fit it to the little one, it should be great for getting into tight corners. Bruce, this one is a bit dearer than the others but it's far more versatile. The quality of mine is excellent, once I had it assembled it worked with no issues. I've mounted it to a slightly larger wooden base so I can clamp it down wherever I want, now I'm trying to figure out how to fit larger, stronger tool supports. Thanks for the belt info, problem is we can't always get the same stuff you can but I'm looking to see what's around. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members hans25 Posted November 25, 2025 Members Report Posted November 25, 2025 Vevor can be hit or miss depending on the product category, but this grinder is one of their better-reviewed tools, and the use of sewing machine components is genius — reliable, and readily available if you ever need parts. Quote jewelerstoolsmall.com supplies jewelry making tools such as ring engraving machines and pearl hole drilling machines online. Orders are welcome.
Members dikman Posted November 25, 2025 Author Members Report Posted November 25, 2025 Unfortunately the controller appears to be a custom job, you can't just replace it with any old sewing machine controller without modifying it. I've bought several items from Vevor over the years and only ever had issues with one - a spot welder for assembling Li-Ion batteries. It kept tripping the circuit breaker when switched on! It turned out to be a poorly designed main transformer so I replaced it with a re-wound microwave transformer that I built. Then it worked as it should with no problems. This issue, by the way, isn't confined to just Vevor, other brands used the same machines with the same results. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
CFM chuck123wapati Posted November 25, 2025 CFM Report Posted November 25, 2025 that is a nice-looking grinder for sure, they also work well for making new tools and sharpening if you can slow them down enough. I use a regular old 4" belt grinder for leather and sharpening and i have a 2x48 for tool work. I have been thinking for a year or two that a cloth belt would be awesome for burnishing, and how I would sew one up that would travel straight, then I might of just had an epiphany. Turning an old belt inside out!!! I'll be finding out how well that works pretty darn soon lol, but it's 4 am and i aint had me bean soup/coffee. lol Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members MarshalWill Posted November 25, 2025 Members Report Posted November 25, 2025 4 hours ago, chuck123wapati said: that is a nice-looking grinder for sure, they also work well for making new tools and sharpening if you can slow them down enough. I use a regular old 4" belt grinder for leather and sharpening and i have a 2x48 for tool work. I have been thinking for a year or two that a cloth belt would be awesome for burnishing, and how I would sew one up that would travel straight, then I might of just had an epiphany. Turning an old belt inside out!!! I'll be finding out how well that works pretty darn soon lol, but it's 4 am and i aint had me bean soup/coffee. lol Maybe you could fashion a leather belt for it if the inside of an abrasive belt doesn't work. Just make a long strip of 3-4 oz leather and glue it to an old abrasive belt. Quote
Moderator bruce johnson Posted November 25, 2025 Moderator Report Posted November 25, 2025 6 hours ago, chuck123wapati said: that is a nice-looking grinder for sure, they also work well for making new tools and sharpening if you can slow them down enough. I use a regular old 4" belt grinder for leather and sharpening and i have a 2x48 for tool work. I have been thinking for a year or two that a cloth belt would be awesome for burnishing, and how I would sew one up that would travel straight, then I might of just had an epiphany. Turning an old belt inside out!!! I'll be finding out how well that works pretty darn soon lol, but it's 4 am and i aint had me bean soup/coffee. lol It depends on what the backing is. X, J, and Y belts all have different backing and their resistance to abrasion even from leather - you might end up with a 48 inch whip slapping you when half the belts strips off and lets go. Been there from the abrasive side. I tried to make my own leather belts, variable tracking and even with good skives - got the "bump" on some. My pals at Red Label Abrasives make a 2x48 leather belt. I have had no problems with the tracking on their leather belts. Here is their link - https://www.redlabelabrasives.com/products/2-x-48-inch-leather-honing-stropping-belt?srsltid=AfmBOoos-c_rllMfxZQM7LMYYmUfVkzVp6k9ViIUrL8olz0wv456cNM1 I swear between different grit diamond paste belts and polishing compound belts I have about as many dedicated leather belts as I do abrasive belts. Life was simpler when I didn't watch as many knifemakers and edge gurus on YouTube. LOL Quote Bruce Johnson Malachi 4:2 "the windshield's bigger than the mirror, somewhere west of Laramie" - Dave Stamey Vintage Refurbished And Selected New Leather Tools For Sale - www.brucejohnsonleather.com
Members dikman Posted November 26, 2025 Author Members Report Posted November 26, 2025 I just made a couple of bigger (longer and deeper) rests, one for horizontal use and one for vertical use. The coarsest grit I've got at the moment is 100, which came with it, but it's pretty good at ripping into the metal even with that. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
