Best way I've found to straighten leather when it comes in to the shop is to dampen it a little and letting it lay flat. You can cut it while it's slightly damp, the knife will go through it easier too. It's not going to hurt the leather just like when you case it for tooling.
I like the tooling options 2, 5, and 7 and would be happy with which ever matched my saddle the closest.
  • Replies 34
  • Created
  • Last Reply
Top Posters In This Topic
I have made some progress in the past few days.  I used the original template for the fender, and cut out a border template.  It would allow me to insure the border I cut into the one side, matched the border I cut into the other.  Why?  Since you can't see both fenders at the same time when they are mounted on the saddle?  Hey, just the way I do things.  I try and do things the right way... or as best I can.
However... before I can actually transfer this pattern to the fenders... there is an issue.  They still retain a curl from the shipping.  As I did with the original fenders, I sprayed them down with a generous mist, and weighted them down on the bench and left them for about six hours, then checked them.  They had flattened considerably, but would benefit greatly from a second treatment.  I repeated the process and left them overnight.
I came out after breakfast the next morning and checked.  Success.  The Fenders were flat and ready to tool.
I used the template to carefully, and LIGHTLY pencil in the pattern.  Using a double border swivel knife, I cut in the border.28borderscut.jpg.1f5b6ec874297bf1ca243f8638c5ee28.jpg
This is detail work, the pucker factor was HIGH.  This type makes my arthritis scream, so I was done for the day.  BUT, I didn't blow it.  Not bad for a Broken Old Marine.  I left this to rest while I rested the hands overnight.
Back at it again, I carefully stamped the tooling pattern around the inside of the border, AFTER I cut the inside line deeper with a swivel knife the blade of which I had re-sharpened and polished.  I now had a clearly defined sharp reference to work from.  Each stamp was checked before I struck it and EACH strike was firm and careful.  I wanted to avoid a glancing blow or a bounce, both of which could ruin the entire line.
In the picture below you can see the border, as well as my Maker's Mark at the bottom of the leg on both Fenders.  Again, Careful Placement, and then even more careful in the strike.  Too much work to blow it now.
A closer look at the border pattern.  This is what she wanted.  I would have gone with a Serpentine Pattern myself, but then... not my saddle. LOL.
Next session, I'll work on dressing up the edges in preparation for applying Watco Oil or stain.  There are some spots I'll want to smooth out the "Line/Flow" of the edges so that we can burnish the edges.  I'll take a couple scrap pieces and make test panels for stains for color comparison.  The owner of the saddle finally sent pics to assist with color match, though she isn't too concerned.  I like to try.
I did get to do some Clean Up work on the blevins, removing old glue, rust, staining...  We'll be reusing the old beat up ones.  They tell me they can't be seen, So why not.
They looked pretty bad originally.... but I was told they aren't all the same, and finding matches might be hard.  Wouldn't want to have to buy a new set of stirrup straps just because the blevins are ugly, when they aren't seen while riding. (I guess)  They can clean them the rest of the way... if they like.
Not sure why you choose to waste so much good original leather. I have fixed lots of those exact problems. Just oil the original fenders to restore them like they should have been taken care of.  Then glue and sew with thin thread a thin patch on the outside and sew a piece of seatbelt from a car on the inside. NO stitching across, only along the direction of pull. Seatbelt is so thin you never notice it and can only be seen when looking on the inside. Patch on outside is barely noticeable.
Not my choice.  I'm making the new fenders as a favor for my daughter for her friend.  The  original fenders are in pretty bad shape however.  Dry and brittle in some areas, and tearing easily in others.  Had not been well cared for it seems.  I'll return the original pieces and the new constructs to the owner when complete.
I don't usually do saddle work, and my holster, sheath, and belt work are all done for personal use or as gifts... Or for pleasure.  I admire the work of the pros here, who know more than I, and try to learn from it...
It's interesting.
Made a mistake, won't use Watco, that's my woodworking finish.  I'll pretreat with neatsfoot oil, then stain.
  • 3 weeks later...
Wow, been away from the topic for a while.  Weather.  We had ten days of snow and ice and because of my physical challenges the wife won't let me out to go to the shop when the footing is challenging.  Thirty surgeries so far and don't need thirty one. LOL.  The weather finally turned decent and I was able to get back out and finish the work.  I was also waiting for hardware.  I had ordered rivets and burrs, but the first set that came in were too short at 1/2", I reordered 1" rivets, and Springfield is a great company, but slow.  It took a week.  I also ordered more Mink Oil, it was a lot faster coming from Amazon, two days.  No matter, stuck in the house ten days.
The view of the Fender Assembly from the rear:
I didn't remake the stirrup straps, the owner didn't ask for them.  I reused the blevins for the same reason.  But, everything went together well.  The shape of the back pieces is by design, she will curl them and lace them to keep them curled.
The view from the front....
For a first attempt, I was happy with the result.  My daughter sent her friend pictures and got back a one word reply.  "Wow!"  I guess she was happy, that's all that matters.
I also needed to repair the Belly Band, (or whatever it's actually called.)  The owner didn't keep the leather clean, it was covered in sweat, dirt, and oils.  I cleaned it with saddle soap and a toothbrush.  My repair was to replace the broken loop that held a D-ring.  Miss T was going to cut back the stitching so I could remove the rivet and the old loop, then replace them.  Then I would saddle stitch the removed stitching.  She took the band into her shop, pulled about 1-1/2" of stitches and discovered they had glued the two panels together.  So I cut a square into the back of the band, and drilled out the rivet.  The loop was glued into place as well.  I cut out as much of the old loop as possible and made a new loop, and put it on with a chicago screw.  Worked well.
A closeup of the new loop.  Unlike the pics of the fenders, this piece hasn't been treated with Mink Oil yet.
I also made new laces so she could wrap the fenders near the blevins like she prefers.  I wasn't going to try and recreate that.  The project is pretty much done at this point.  I'll be back to sheaths and holsters, a belt now and then.
