Members ThisIsMyFirstRodeo Posted 23 hours ago Members Report Posted 23 hours ago Okay, sorry if my tone is a bit different in this post, but I just ruined 2 straps (4pcs) in a row because the straps were nudged ever so slightly and the grain got glue on it. I would be able to bevel it off on a wider strap, but taking ⅛” in on both sides of a ½” strap is what I would call unacceptable. So just how do you glue a ½” x 60”+ strap without getting glue on the grain? AZR Quote
Members PeterinID Posted 23 hours ago Members Report Posted 23 hours ago I glue first and then trim to size. Quote
CFM chuck123wapati Posted 23 hours ago CFM Report Posted 23 hours ago (edited) 12 minutes ago, ThisIsMyFirstRodeo said: So just how do you glue a ½” x 60”+ strap without getting glue on the grain? AZR use tape Edited 23 hours ago by chuck123wapati Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
CFM chuck123wapati Posted 23 hours ago CFM Report Posted 23 hours ago https://tandyleather.com/collections/adhesives/products/2535-650-tanners-bond-adhesive-tape Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
kgg Posted 22 hours ago Report Posted 22 hours ago (edited) 1 hour ago, ThisIsMyFirstRodeo said: So just how do you glue a ½” x 60”+ strap without getting glue on the grain? Interesting, I'm just finishing two 6' dog leads one is 1/2" and the other is 3/4". The 1/2" lead only had the interior of the hand and the fold over section at the clip end glued but was still sewn along the edges with V138 bonded nylon. The 3/4" x 6' was two pieces of 6.5 oz glue together and sewn along the edges along the edges with V138 bonded nylon. How I glued: i) I have a slightly raised metal edge along the edge of my work table that I push the strap up against ii) I use a small piece of 3/4" x 3/4" x 10" long aluminum angle that I push up against the other edge of the strap. iii) I apply contact cement to the strap basically in 10" sections as I move the 10" AL angle along the length. w and let dry then reapply a second coat of contact cement. iv) Then I hang the strap of the door to the room to dry. v) Wipe the metal edging and 10" AL angle so there is no excess contact cement. vi) Lay the second piece up against the raised edge and apply contact cement and hang the strap over the door. vii) Clean metal edges and apply a second coat to the first strap. Rinse and repeat for the second strap. Let dry hanging over door. I do two coats as I have found the first coat gets sucked into the leather and sometimes doesn't bond properly. viii) Clean metal edges and lay a strap up against the work table edge. ix) Apply second strap to the first strap in small sections while pushing both straps up against the work table raised edge, like one inch or less lengths. x) I then use a 4" metal roller to roll the complete strap to get rid of any possible bubbles. I robbed my roller from the kitchen draw, I guess it was supposedly used for baking. xi) I then have a flat piece of metal that I put on top of the now freshly glued strap and clamp it down for about 24 hours to cure under pressure. xii) I then sew along the edges, about 4 or 5mm in, with V138 bonded nylon. 58 minutes ago, chuck123wapati said: use tape I do like that idea and will try incorporating it on the next one. kgg Edited 22 hours ago by kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
CFM chuck123wapati Posted 21 hours ago CFM Report Posted 21 hours ago 54 minutes ago, kgg said: Interesting, I'm just finishing two 6' dog leads one is 1/2" and the other is 3/4". The 1/2" lead only had the interior of the hand and the fold over section at the clip end glued but was still sewn along the edges with V138 bonded nylon. The 3/4" x 6' was two pieces of 6.5 oz glue together and sewn along the edges along the edges with V138 bonded nylon. How I glued: i) I have a slightly raised metal edge along the edge of my work table that I push the strap up against ii) I use a small piece of 3/4" x 3/4" x 10" long aluminum angle that I push up against the other edge of the strap. iii) I apply contact cement to the strap basically in 10" sections as I move the 10" AL angle along the length. w and let dry then reapply a second coat of contact cement. iv) Then I hang the strap of the door to the room to dry. v) Wipe the metal edging and 10" AL angle so there is no excess contact cement. vi) Lay the second piece up against the raised edge and apply contact cement and hang the strap over the door. vii) Clean metal edges and apply a second coat to the first strap. Rinse and repeat for the second strap. Let dry hanging over door. I do two coats as I have found the first coat gets sucked into the leather and sometimes doesn't bond properly. viii) Clean metal edges and lay a strap up against the work table edge. ix) Apply second strap to the first strap in small sections while pushing both straps up against the work table raised edge, like one inch or less lengths. x) I then use a 4" metal roller to roll the complete strap to get rid of any possible bubbles. I robbed my roller from the kitchen draw, I guess it was supposedly used for baking. xi) I then have a flat piece of metal that I put on top of the now freshly glued strap and clamp it down for about 24 hours to cure under pressure. xii) I then sew along the edges, about 4 or 5mm in, with V138 bonded nylon. I do like that idea and will try incorporating it on the next one. kgg lol with tape 1. Apply tape; you can even buy repositionable tape, sew. I doubt it takes a minute to use the tape. And no glue on the grain side!!!! Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
AlZilla Posted 21 hours ago Report Posted 21 hours ago 2 hours ago, PeterinID said: I glue first and then trim to size. Simplicity. Very nice. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
