Members wood Posted February 28, 2008 Members Report Posted February 28, 2008 I just put some cement on the gullet piece for a rough out saddle and it is not bonding to the slick side of the leather. Just wondering your thoughts. Old glue?? It's only been out of the can and in the pot for a month or so. I glued some leather to the seat strainer yesterday and it bonded fine. The glue also seemed to bond ok with the tree. But when it's on the leather and I let it sit for five to ten minutes, you can just rub it with your finger and it rolls up and leaves the leather looking like nothing was ever on it. I've used Barge for a while but this is the first time this has happened. Any ideas? Quote
Contributing Member barra Posted February 28, 2008 Contributing Member Report Posted February 28, 2008 well it sounds like it is going off because you can roll it off the item you put it on and it has adhered other items. Sounds like the smooth grain side of the leather needs to be roughed up to give you good adhesion. you can use a knife point, broken glass, course sandpaper, wire welders brush etc to rough it up Barra Quote
TracyMoss Posted February 28, 2008 Report Posted February 28, 2008 Even if you rough up the smooth side, when the leather is too wet it will peel off. Make sure that your leather is mostly dry before you apply it. I always block out my gullet and mark it off before I put it in. If you have done these things then maybe your glue needs to be thinned down a little. hope this helps. TM Quote
Members D.A. Kabatoff Posted February 28, 2008 Members Report Posted February 28, 2008 Hey Wood, I'd try what the others suggested, rough up that grain and apply the glue on dryer leather... something else that works if you're really having problems is to thin up some glue with thinner so that it's very runny. Apply that to the leather first cause it'll absorb into the leather better; let it dry for a good hour or more (overnight if you can plan your work around it). After that first coat is nice and dry you can wet your leather again to make it a little easier to work with; dry the water off the dried glue and apply a regular coat of glue to it and let it set as normal and it should stick to anything. Darc Quote
Moderator bruce johnson Posted February 28, 2008 Moderator Report Posted February 28, 2008 I'm with Darcy too. In fact on my parts, I will rough up the grain side, apply the thin cement to the dry leather, let the first coat dry, and then give it a bath. Then when it comes out, wipe the water off the glued surface, apply another coat. When everything is the right temper, fan a paint stripping gun across the dried cement. This will activate it (make it more sticky) and then slap it down. I am told this is what Barge is designed for by the shoe and boot folk - being heat activated. I have never been impressed with Barge's ability to stick to leather that is wet initially. I have a full size fire extinguisher in my shop, and have never had need for it with the paint stripping gun and Barge, even on high. I have tried to light it up and can't get it to go. However, I did touch a sort of freshly glued in zipper end that was a bit frayed to a candle to seal the fray. That will light up your life. Note to self, no open flames with Barge. Quote
Members Studio-N Posted February 28, 2008 Members Report Posted February 28, 2008 Was it the 2 oz tube of barge or the Quart can or better that you used? It wasn't advertised, but Barge did reformulate their glue. You have to shake up the cans to mix the two major components up. peace. Quote
Members Ronny Posted February 28, 2008 Members Report Posted February 28, 2008 Some thing is different about Bargs glue. I opened a new gal can yesterday and it seems stronger smelling(if possible) and it was a clear copper color. I glued some skirt plugs and forgot them for an hr or so and needed to reposition one and it peeled off like rubber glue. Sure not a permanent bond like the old stuff. Ronny Quote
Members Steve Posted February 28, 2008 Members Report Posted February 28, 2008 I had the same problem the other day, plugs peeled right off. I put another coat of glue on and they stuck like they should. I have no idea why they didn't stick the first time. Quote
Members jwwright Posted February 28, 2008 Members Report Posted February 28, 2008 Anybody been using the Duall 88 Cement? I got a couple quarts of it from Siegels, and like it just fine. It is thinner than the Barge, and it is clear. Quote
TracyMoss Posted February 28, 2008 Report Posted February 28, 2008 I use Master's. Wouldn't go back to Barge if you shot me. Quote
Doug C Posted February 28, 2008 Report Posted February 28, 2008 where do I find Master's? Thanks, Doug Quote
Members wood Posted February 28, 2008 Author Members Report Posted February 28, 2008 Thanks for all the replys. I think it may have been the too wet thing. I had roughed up the grain side and still wouldn't work great. I'll form it again tonight and let it dry then put the glue on. Thank y'all again for the help. Quote
Members Randy Cornelius Posted February 28, 2008 Members Report Posted February 28, 2008 I know some you you really like barge but I will never use it again, simply because of the problems I have had in the past about it not sticking to wet leather. I have been using Duall 88 for the last couple years with great results. I find that the Duall 88 does not have to be thinned like the barge had to be. It remains the same consistancy from gal to gal. I have used Masters before and it works very well but the fumes it puts off is something else. I work in my basement and the exhaust fan will not draw out the Masters without it going through out the house. You also have to have a tax ID to buy Masters. Randy Quote
Members kseidel Posted February 29, 2008 Members Report Posted February 29, 2008 R H products that makes Duall 88 makes a cement called XL8. It is not quite as fast, but the bond is much stronger, and it will stick to oily surfaces. Is thin and penetrates well for a pre-wetting coat. Takes a bit to get used to as it works different than barge or masters, but I like it the best of all cements on the market. Keith Quote
Moderator bruce johnson Posted February 29, 2008 Moderator Report Posted February 29, 2008 While we are talking glues here, does anybody have experience with using EMU's SAR 36 cement? Quote
Members Randy Cornelius Posted February 29, 2008 Members Report Posted February 29, 2008 where do I find Master's?Thanks, Doug Anywhere that has shoe repair will have it. Sheridan Leather Outfitters carried it the last time I was there I seen it. RC Quote
TracyMoss Posted February 29, 2008 Report Posted February 29, 2008 where do I find Master's?Thanks, Doug Doug, contact www.panhandleleather.com they are the cheapest I know of. They will sell it to you. Quote
Members RyanCope Posted February 29, 2008 Members Report Posted February 29, 2008 Like some of you I quit using Barge a few years back. It won't stick to latigo easily. Used Masters for a few years. Currently using a german brand called Renia. Wow! WARNING. This stuff should only be used by hard core glue lovers. Ryan Cope Quote
Members AndyKnight Posted February 29, 2008 Members Report Posted February 29, 2008 I havn't used barge for about 15 years. I quit when I stopped fixing boots. I use contact cement which is available at any building supply co. As well, I have also started using a helmefix latex base contact cement to get away from the fumes. It works well , sticks incredibly stong. downside is it takes a lot longer to dry to be ready to stick. If it isn't dry it just won't stick. Quote
JAM Posted September 6, 2008 Report Posted September 6, 2008 where do I find Master's?Thanks, Doug I pick up Master's at Tandy(the Leather Factory) in Spokane, WA - it's not on the shelves, but they keep it in the back room for commercial (tax ID) customers only, so you have to ask for it. It's probably at other Tandy/Leather Factory stores, also. Julia Quote
Members Leerwerker Posted September 6, 2008 Members Report Posted September 6, 2008 where do I find Master's?Thanks, Doug TANDY carries the Masters and Masters Solvent Quote
esantoro Posted September 6, 2008 Report Posted September 6, 2008 R H products that makes Duall 88 makes a cement called XL8. It is not quite as fast, but the bond is much stronger, and it will stick to oily surfaces. Is thin and penetrates well for a pre-wetting coat. Takes a bit to get used to as it works different than barge or masters, but I like it the best of all cements on the market. Keith Keith, What I like about Duall is that it works well and the fumes aren't too strong. I like that XL8 has an even stronger bond. Are the fumes very strong with the XL8? Ed Quote
esantoro Posted September 16, 2008 Report Posted September 16, 2008 Keith,What I like about Duall is that it works well and the fumes aren't too strong. I like that XL8 has an even stronger bond. Are the fumes very strong with the XL8? Ed Just got the xl8 in. Fumes are much stronger than they are in the Duall 88, which looks and smells a lot like weldwood. ed Quote
esantoro Posted September 20, 2008 Report Posted September 20, 2008 I know some you you really like barge but I will never use it again, simply because of the problems I have had in the past about it not sticking to wet leather. I have been using Duall 88 for the last couple years with great results. I find that the Duall 88 does not have to be thinned like the barge had to be. It remains the same consistancy from gal to gal. I have used Masters before and it works very well but the fumes it puts off is something else. I work in my basement and the exhaust fan will not draw out the Masters without it going through out the house. You also have to have a tax ID to buy Masters.Randy Randy, Where are you getting your Duall #88 in the gallon? I just tried the xl-8, and I think the #88 is better. ed Quote
esantoro Posted September 20, 2008 Report Posted September 20, 2008 Keith,What I like about Duall is that it works well and the fumes aren't too strong. I like that XL8 has an even stronger bond. Are the fumes very strong with the XL8? Ed My first impression with the xl-8 is that it doesn't provide a stronger bond than the 88 does. Maybe it provides a stronger bond over time. ed Quote
